Hi Sindy, I have try as you suggested. The results are below.
This is if I connect to port 80 with my phone.
18:32:20 firewall,info dst-nat rule 40080: dstnat: in:pppoe-3bbfttx-ether1 out:(unknown 0), proto TCP (SYN), my.lte.ip:46964->mikrotik.public.ip:40080, len 60
18:32:20 firewall,info to server: postrouting: in:(unknown 0) out:bridge, proto TCP (SYN), my.lte.ip:46964->my.home.server:40080, NAT my.lte.ip:46964->(mikrotik.public.ip:40080->my.home.server:40080), len 60
18:32:20 firewall,info from server: prerouting: in:bridge out:(unknown 0), src-mac ***, proto TCP (SYN,ACK), my.home.server:40080->my.lte.ip:46964, NAT (my.home.server:40080->mikrotik.public.ip:40080)->my.lte.ip:46964, len 60
18:32:20 firewall,info to server: postrouting: in:(unknown 0) out:bridge, src-mac ***, proto TCP (ACK), my.lte.ip:46964->my.home.server:40080, NAT my.lte.ip:46964->(mikrotik.public.ip:40080->my.home.server:40080), len 52
18:33:25 firewall,info from server: prerouting: in:bridge out:(unknown 0), src-mac ***, proto TCP (ACK,FIN), my.home.server:40080->my.lte.ip:46964, NAT (my.home.server:40080->mikrotik.public.ip:40080)->my.lte.ip:46964, len 52
18:33:25 firewall,info to server: postrouting: in:(unknown 0) out:bridge, src-mac ***, proto TCP (ACK,FIN), my.lte.ip:46964->my.home.server:40080, NAT my.lte.ip:46964->(mikrotik.public.ip:40080->my.home.server:40080), len 52
18:33:25 firewall,info from server: prerouting: in:bridge out:(unknown 0), src-mac ***, proto TCP (ACK), my.home.server:40080->my.lte.ip:46964, NAT (my.home.server:40080->mikrotik.public.ip:40080)->my.lte.ip:46964, len 52
This is when I connect to port 40080 with my phone.
18:36:44 firewall,info "dst-nat rule 80: " dstnat: in:pppoe-3bbfttx-ether1 out:(unknown 0), proto TCP (SYN), my.lte.ip3:36185->mikrotik.public.ip:80, len 60
18:36:44 firewall,info to server: postrouting: in:(unknown 0) out:bridge, proto TCP (SYN), my.lte.ip3:36185->my.home.server:40080, NAT my.lte.ip:36185->(mikrotik.public.ip:80->my.home.server:40080), len 60
18:36:44 firewall,info from server: prerouting: in:bridge out:(unknown 0), src-mac ***, proto TCP (SYN,ACK), my.home.server:40080->my.lte.ip3:36185, NAT (my.home.server:40080->mikrotik.public.ip:80)->my.lte.ip:36185, len 60
18:36:45 firewall,info from server: prerouting: in:bridge out:(unknown 0), src-mac ***, proto TCP (SYN,ACK), my.home.server:40080->my.lte.ip3:36185, NAT (my.home.server:40080->mikrotik.public.ip:80)->my.lte.ip:36185, len 60
18:36:45 firewall,info to server: postrouting: in:(unknown 0) out:bridge, proto TCP (SYN), my.lte.ip3:36185->my.home.server:40080, NAT my.lte.ip3:36185->(mikrotik.public.ip:80->my.home.server:40080), len 60
18:36:47 firewall,info from server: prerouting: in:bridge out:(unknown 0), src-mac ***, proto TCP (SYN,ACK), my.home.server:40080->my.lte.ip3:36185, NAT (my.home.server:40080->mikrotik.public.ip:80)->my.lte.ip:36185, len 60
18:36:47 firewall,info to server: postrouting: in:(unknown 0) out:bridge, proto TCP (SYN), my.lte.ip3:36185->my.home.server:40080, NAT my.lte.ip:36185->(mikrotik.public.ip:80->my.home.server:40080), len 60
/ip firewall nat print
0 D chain=dstnat action=jump jump-target=hotspot hotspot=from-client
1 D chain=hotspot action=jump jump-target=pre-hotspot
2 D chain=hotspot action=redirect to-ports=64872 protocol=udp dst-port=53
3 D chain=hotspot action=redirect to-ports=64872 protocol=tcp dst-port=53
4 D chain=hotspot action=redirect to-ports=64873 protocol=tcp hotspot=local-dst dst-port=80
5 D chain=hotspot action=redirect to-ports=64875 protocol=tcp hotspot=local-dst dst-port=443
6 D chain=hotspot action=jump jump-target=hs-unauth protocol=tcp hotspot=!auth
7 D chain=hotspot action=jump jump-target=hs-auth protocol=tcp hotspot=auth
8 D chain=hs-unauth action=redirect to-ports=64874 protocol=tcp dst-port=80
9 D chain=hs-unauth action=redirect to-ports=64874 protocol=tcp dst-port=3128
10 D chain=hs-unauth action=redirect to-ports=64874 protocol=tcp dst-port=8080
11 D chain=hs-unauth action=redirect to-ports=64875 protocol=tcp dst-port=443
12 D chain=hs-unauth action=jump jump-target=hs-smtp protocol=tcp dst-port=25
13 D chain=hs-auth action=redirect to-ports=64874 protocol=tcp hotspot=http
14 D chain=hs-auth action=jump jump-target=hs-smtp protocol=tcp dst-port=25
15 X ;;; place hotspot rules here
chain=unused-hs-chain action=passthrough
16 chain=srcnat action=masquerade out-interface=pppoe-3bbfttx-ether1 log=no log-prefix=""
17 chain=dstnat action=dst-nat to-addresses=my.home.server to-ports=40080 protocol=tcp in-interface=pppoe-3bbfttx-ether1 dst-port=80 log=yes
log-prefix=""dst-nat rule 80: ""
18 chain=dstnat action=dst-nat to-addresses=my.home.server to-ports=80 protocol=tcp dst-port=20080 log=no log-prefix=""
19 X chain=dstnat action=dst-nat to-addresses=my.home.server to-ports=11111 protocol=tcp dst-port=11111 log=yes log-prefix=""
20 chain=dstnat action=dst-nat to-addresses=my.home.server to-ports=55557 protocol=tcp dst-port=55557 log=no log-prefix=""
21 chain=dstnat action=dst-nat to-addresses=my.home.server to-ports=55557 protocol=udp dst-port=55557 log=no log-prefix=""
22 chain=dstnat action=dst-nat to-addresses=my.home.server to-ports=8008 protocol=tcp dst-port=8008 log=no log-prefix=""
23 chain=dstnat action=dst-nat to-addresses=my.home.server to-ports=8009 protocol=tcp dst-port=8009 log=no log-prefix=""
24 chain=dstnat action=dst-nat to-addresses=my.home.server to-ports=9091 protocol=tcp dst-port=9091 log=no log-prefix=""
25 chain=dstnat action=dst-nat to-addresses=my.home.server to-ports=22 protocol=tcp src-address-list=!blacklist dst-port=22000 log=yes log-prefix="server-ssh:"
26 chain=dstnat action=dst-nat to-addresses=my.home.server to-ports=8443 protocol=tcp dst-port=8443 log=no log-prefix=""
27 chain=dstnat action=dst-nat to-addresses=my.home.server to-ports=5201 protocol=tcp dst-port=5201 log=no log-prefix=""
28 chain=dstnat action=dst-nat to-addresses=my.home.server to-ports=40080 protocol=tcp dst-port=40080 log=yes log-prefix="dst-nat rule 40080: "
29 chain=srcnat action=masquerade protocol=tcp src-address=10.0.0.0/8 dst-address=my.home.server dst-port=8008 log=no log-prefix=""
30 chain=srcnat action=masquerade src-address=10.192.0.0/10 dst-address=my.onu.ip out-interface=ether1 log=no log-prefix=""
31 chain=srcnat action=masquerade protocol=tcp src-address=10.0.0.0/8 dst-address=my.home.server dst-port=5201 log=no log-prefix=""
32 chain=srcnat action=masquerade protocol=tcp src-address=10.0.0.0/8 dst-address=my.home.server dst-port=8443 log=no log-prefix=""
33 chain=dstnat action=dst-nat to-addresses=my.device to-ports=8000 protocol=tcp dst-port=8000 log=no log-prefix=""
34 chain=srcnat action=masquerade protocol=tcp src-address=10.0.0.0/8 dst-address=my.device dst-port=8000 log=no log-prefix=""
35 chain=dstnat action=dst-nat to-addresses=my.home.server to-ports=11940 protocol=tcp dst-port=11940 log=yes log-prefix="server-pvpn: "
36 X chain=srcnat action=masquerade to-ports=80 protocol=tcp src-address=10.192.0.0/10 dst-address=my.home.server dst-port=80 log=no log-prefix=""
/ip firewall filter print
0 D ;;; special dummy rule to show fasttrack counters
chain=forward action=passthrough
1 D chain=forward action=jump jump-target=hs-unauth hotspot=from-client,!auth
2 D chain=forward action=jump jump-target=hs-unauth-to hotspot=to-client,!auth
3 D chain=input action=jump jump-target=hs-input hotspot=from-client
4 D chain=input action=drop protocol=tcp hotspot=!from-client dst-port=64872-64875
5 D chain=hs-input action=jump jump-target=pre-hs-input
6 D chain=hs-input action=accept protocol=udp dst-port=64872
7 D chain=hs-input action=accept protocol=tcp dst-port=64872-64875
8 D chain=hs-input action=jump jump-target=hs-unauth hotspot=!auth
9 D chain=hs-unauth action=reject reject-with=tcp-reset protocol=tcp
10 D chain=hs-unauth action=reject reject-with=icmp-net-prohibited
11 D chain=hs-unauth-to action=reject reject-with=icmp-host-prohibited
12 X ;;; place hotspot rules here
13 ;;; defconf: fasttrack
chain=forward action=fasttrack-connection connection-state=established,related log=no log-prefix=""
14 ;;; defconf: accept established,related
chain=forward action=accept connection-state=established,related log=no log-prefix=""
15 ;;; defconf: drop invalid
chain=forward action=drop connection-state=invalid log=no log-prefix=""
16 chain=input action=drop src-address-list=blacklist log=yes log-prefix="Firewall input blacklist:"
17 ;;; defconf: drop all from WAN not DSTNATed
chain=forward action=drop connection-state=new connection-nat-state=!dstnat in-interface=pppoe-3bbfttx-ether1 log=no log-prefix=""
18 chain=input action=accept protocol=icmp
19 chain=input action=accept connection-state=established
20 chain=input action=accept connection-state=related
21 chain=input action=drop in-interface=pppoe-3bbfttx-ether1
/ip firewall mangle print
chain=prerouting action=passthrough
1 D ;;; special dummy rule to show fasttrack counters
2 D ;;; special dummy rule to show fasttrack counters
chain=postrouting action=passthrough
3 chain=postrouting action=log protocol=tcp dst-address=my.home.server dst-port=40080 log-prefix="to server: "
4 chain=prerouting action=log protocol=tcp src-address=my.home.server src-port=40080 log-prefix="from server: "
