I am having a hard time getting WPA (tkip) to work using a 64 Char hex key
Does MT support 256 Bit WPA?
MY log error is “unicast key exchange timeout”
If is use a shorter key (13 char) all is well
At this point all im trying to connect from is a Windows XP sp2 notebook.
Please take a look at my config and tell me what im doing wrong.
I hope this is enough information.
Thank you
RouterOS 3.0rc1
software id =
set default authentication-types=“” eap-methods=passthrough group-ciphers=“”
group-key-update=5m interim-update=0s mode=none name=“default”
radius-eap-accounting=no radius-mac-accounting=no
radius-mac-authentication=no radius-mac-caching=disabled
radius-mac-format=XX:XX:XX:XX:XX:XX radius-mac-mode=as-username
static-algo-0=none static-algo-1=none static-algo-2=none
static-algo-3=none static-key-0=“” static-key-1=“” static-key-2=“”
static-key-3=“” static-sta-private-algo=none static-sta-private-key=“”
static-transmit-key=key-0 supplicant-identity=“MikroTik”
tls-certificate=none tls-mode=no-certificates unicast-ciphers=“”
wpa-pre-shared-key=“” wpa2-pre-shared-key=“”
add authentication-types=wpa-psk group-ciphers=tkip group-key-update=5m
interim-update=0s mode=dynamic-keys name=“WPA” radius-eap-accounting=no
radius-mac-accounting=no radius-mac-authentication=no
radius-mac-caching=disabled radius-mac-format=XX:XX:XX:XX:XX:XX
radius-mac-mode=as-username static-algo-0=none static-algo-1=none
static-algo-2=none static-algo-3=none static-key-0=“” static-key-1=“”
static-key-2=“” static-key-3=“” static-sta-private-algo=none
static-sta-private-key=“” static-transmit-key=key-0 supplicant-identity=“”
tls-certificate=none tls-mode=no-certificates unicast-ciphers=tkip
wpa-pre-shared-key=“446824674961466842277365572c3e76632d3b624372655443516a3
d58246874” wpa2-pre-shared-key=“”
/interface wireless
set 0 ack-timeout=dynamic allow-sharedkey=no antenna-gain=0 antenna-mode=ant-a
area=“” arp=enabled band=2.4ghz-b/g basic-rates-a/g=6Mbps
basic-rates-b=1Mbps burst-time=disabled comment=“” compression=no
country=no_country_set default-ap-tx-limit=0 default-authentication=yes
default-client-tx-limit=0 default-forwarding=yes dfs-mode=none
disable-running-check=no disabled=no disconnect-timeout=3s
frame-lifetime=0 frequency=2437 frequency-mode=manual-txpower hide-ssid=no
hw-retries=15 mac-address=00:0B:6B:37:B0:51 max-station-count=2007
mode=ap-bridge mtu=1500 name=“wlan1” noise-floor-threshold=default
on-fail-retry-time=100ms periodic-calibration=default
periodic-calibration-interval=60 preamble-mode=both
proprietary-extensions=post-2.9.25 radio-name=“000B6B37B051”
rate-set=default scan-list=default security-profile=WPA ssid=“WPATEST”
station-bridge-clone-mac=00:00:00:00:00:00
supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps
supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps tx-power-mode=default
update-stats-interval=disabled wds-cost-range=50-150
wds-default-bridge=none wds-default-cost=100 wds-ignore-ssid=no
wds-mode=disabled wmm-support=disabled
set 1 ack-timeout=dynamic allow-sharedkey=no antenna-gain=0 antenna-mode=ant-a
disable-running-check=no disabled=yes disconnect-timeout=3s
frame-lifetime=0 frequency=2412 frequency-mode=manual-txpower hide-ssid=no
hw-retries=15 mac-address=00:0B:6B:35:8D:C5 max-station-count=2007
mode=ap-bridge mtu=1500 name=“wlan2” noise-floor-threshold=default
proprietary-extensions=post-2.9.25 radio-name=“000B6B358DC5”
rate-set=default scan-list=default security-profile=default
ssid=“MikroTik” station-bridge-clone-mac=00:00:00:00:00:00
/interface wireless align
set active-mode=yes audio-max=-20 audio-min=-100
audio-monitor=00:00:00:00:00:00 filter-mac=00:00:00:00:00:00
frame-size=300 frames-per-second=25 receive-all=no ssid-all=no
/interface wireless sniffer
set channel-time=200ms file-limit=10 file-name=“” memory-limit=10
multiple-channels=no only-headers=no receive-errors=no
streaming-enabled=no streaming-max-rate=0 streaming-server=0.0.0.0
/interface wireless snooper
set channel-time=200ms multiple-channels=yes receive-errors=no
[admin@MikroTik] /interface wireless>
