Hello, we have a Mikrotik installed from a previous IT guy. All working fine using a Draytek Modem to connect to BT (UK ISP).
We have tried three different Mirkotiks and we cannot for the life of us get it to give us internet access when connecting to the same Draytek Modem for BT.
Interfaces - click +button, add PPPoE client
On general tab, change name and select interface going out to modem
Click use Peer DNS and Dial on demand and click ok
Tried so many help files from different tech supports, youtube videos etc.
It still does not work
Plugging in the previously setup Mikrotik and that works fine. In a newly setup mikrotik we can do a ping inside the Mikrotik and that works to find 8.8.4.4 etc.
But no internet access.
Are you certain the Draytek modem is acting as a modem and not routing to a DMZ’d IP address?
I am UK based with similar setup (HG612 modem into a MikroTik) and when using BT had no issues at all.
For a start don’t use dial on demand, it’s not needed.
Can you post a /export hide-senstitive and I’ll compare it to my config, I’m sure there will be a really simple explanation for this.
The firewall and NAT rules use interface lists to specify roles, and you haven’t updated the WAN interface list to reflect the actual WAN interface.
Add
add interface=pppoe-bt list=WAN
and upgrade RouterOS to the latest long-term (currently v6.44.5) as that version has known vulnerabilities.
Edit - leaving the defaults of ether1 in the WAN interface list and DHCP client on ether1 in place will also allow access to the Draytek web UI at http://192.168.2.1
Another edit - if the DHCP client is left for managment access to the Draytek modem then the add default route, peer DNS and peer NTP options should be disabled so it becomes
