cannot get challenge error on RB1000
We have problem with API on RB1000. During login it shouts “cannot get challenge” (and the 5s timeout doesn’t work). This problem exists only on RB1000. We tried with Intel based hardware and everything works without problem. THe stangest thing is, that it was working week ago !
Best Regards,
Lukasz Tylski
are you trying yo connect to it using python client on wiki?
No, using PHP. This worked before. I think it stopped working after upgrade from 3.21 to 3.22.
Regards,
Lukasz Tylski
It works only a few days after reboot.
Regards,
Lukasz
i ran this command on RB1000
/system/resource/print
and this is the result:
!re
=uptime=1w3d02:49:13
=version=3.23
=free-memory=487736
=total-memory=517016
=cpu=e500v2
=cpu-count=1
=cpu-frequency=1333
=cpu-load=7
=free-hdd-space=37060
=total-hdd-space=61440
=write-sect-since-reboot=2885834
=write-sect-total=100872855
=bad-blocks=0
=architecture-name=powerpc
=board-name=RB1000
ok, it is not 3.22, but it is older 3.23 build. And as you can see, it is up for 10 days
OK, I know that’s not only a problem with 3.22 because it works on other x86 based machine !
Ha, from 3.23 problems went away ! … untill 3.30… The same problems again…
