Cannot get Flashfig to Fully Flash - Hap Lite
  1. I run an export on a working config on latest firmware / routeros version.
  2. Set up flashfig on my computer with latest up to date version
  3. Flash new Hap lite with the rsc file and it takes under 2 seconds.
  4. Reboot
  5. Check the new unit and it has only part of the config.
  6. Troubleshooting - I copy and paste the config line by line into terminal - no errors and it all works
I’m at a loss what to do at this point. I’ve tried multiple units. I can’t find any errors obviously.
The only clue I have is WLAN2 actually is disabled. But I can see settings in the script after the wireless parts are applied.
Anyone else having issues getting HAP’s to flash?
Ultimately I want our config on there so when a customer resets their router it’ll go to our config not the default config.
Anyone anyone? Nobody uses flashfig?
