When I try to connect to my Groove through Winbox, it shows the ip address and the MAC of the Groove but returns “connection refused”. I have checked that the firewall is disabled and even reset the Groove but I still cannot get connected. How do I fix this?
Give you network card on your pc a fixed IP-adres in the same IP-range from the groove.
Is your problem solved or not?
Problem solved. Thank you. How do I give you Karma? Owe you 2. Thanks again.
klik on the + on the left site
See printscreen an made
Thanks for that
