Cannot get LTE to work
I am a Mikrotik beginner.
I bought a ID: RBSXTR&R11e-4G
I have checked some tutorials and it seemed pretty easy to get it running,
but in my case I get no connection from the ISP.
I have entered the sim PIN and ISP APN that I found on their webpage. (telia.se)
can somewone enlighten me what I have done wrong?
[admin@MikroTik] > /interface lte info lte1 once
           pin-status: ok
  registration-status: searching
        functionality: full
         manufacturer: MikroTik
                model: R11e-4G
             revision: R11e-4G_V005
                 imei: xxx
                 imsi: xxx
Log:
[admin@MikroTik] > /log print
00:30:39 system,info router rebooted
00:30:48 bridge,info hardware offloading activated on bridge "bridge" ports: ether1
00:30:48 bridge,info hardware offloading activated on bridge "bridge" ports: ether2
00:30:50 interface,info ether1 link up (speed 100M, full duplex)
00:30:51 system,info,account user admin logged in from FC:AA:14:22:9D:21 via winbox
00:30:51 lte,async lte1: sent ATE0
00:30:51 system,info,account user admin logged in via local
00:30:53 lte,async lte1: sent ATE0
00:30:53 lte,async lte1: rcvd OK
00:30:53 lte,async lte1: sent AT+CGMI
00:30:53 lte,async lte1: rcvd MikroTik
00:30:53 lte,async lte1: sent AT+CGMM
00:30:53 lte,async lte1: rcvd R11e-4G
00:30:53 lte,async lte1: sent AT+CGMR
00:30:53 lte,async lte1: rcvd R11e-4G_V005
00:30:53 lte,async lte1: sent AT+CGSN
00:30:53 lte,async lte1: rcvd 359147090101292
00:30:53 lte,async lte1: sent AT+CFUN?
00:30:53 lte,async lte1: rcvd +CFUN: 0
00:30:53 lte,async lte1: sent AT+CMEE=2
00:30:53 lte,async,event %CMEEU: 2
00:30:53 lte,async lte1: sent AT+CREG=2
00:30:53 lte,async lte1: sent AT+CGREG=2
00:30:53 lte,async lte1: rcvd +CME ERROR: operation not supported
00:30:53 lte,async lte1: sent AT+CEREG=2
00:30:53 lte,async lte1: sent AT+CGEREP=2,0
00:30:53 lte,async lte1: sent AT+CMGF=0
00:30:53 lte,async lte1: sent AT+CNMI=1,1,0,1,0
00:30:53 lte,async lte1: sent AT+CPIN?
00:30:53 lte,async lte1: rcvd +CPIN: READY
00:30:53 lte,async lte1: sent AT+CFUN=1
00:30:57 lte,async lte1: sent AT+CPMS="SM","SM","SM"
00:30:57 lte,async lte1: rcvd +CPMS: 0,20,0,20,0,20
00:30:57 lte,async lte1: sent AT+CFUN?
00:30:57 lte,async lte1: rcvd +CFUN: 1
00:30:57 lte,async lte1: sent AT+CNUM
00:30:57 lte,async lte1: sent AT+CIMI
00:30:57 lte,async lte1: rcvd [numbers]
00:30:57 lte,async lte1: sent AT+CPIN?
00:30:57 lte,async lte1: rcvd +CPIN: READY
00:30:57 lte,async lte1: sent AT%PDNSET=1,"online.telia.se","IP","NONE","",""
00:30:57 lte,async lte1: rcvd OK
00:30:58 lte,async lte1: sent at%cmatt=1
00:30:58 lte,async lte1: rcvd OK
00:30:58 lte,debug lte1: config ok
Best regards
Mikael
Are you sure you bought the correct model, I.e. There are 2 X SXT LTE models, supporting different LTE bands?
