Cannot get sfp-sfplus2 ports to activate
I'm trying to setup a pair of CCR2116-12G-4S+ routers in my lab to simulate the internet connection I'll have once Lumen delivers my circuit. I've put the following very basic router config on both devices. From each router I can ping it's own interface but I cannot seem to ping from router1 -> router2 or vice versa.
I also can't seem to get a link up status on sfp-sfpplus2 ports and there's no link lights, I've tried different SFPs but these are all brand new routers, cables and sfp modules. Anyone point me at what I'm doing wrong? Or what step I missed to get those ports to activate?
The SFP modules I'm using are Mikrotik XS+85LC01D with a brand new LC-LC single mode cable between the two.
It also looks like the SFP port is flapping between "no-link" and "initializing" when I run /interface ethernet monitor sfp-sfpplus2 to see what's going on.
[admin@MikroTik] > /interface ethernet monitor sfp-sfpplus2
status: no-link
auto-negotiation: done
supported: 10M-baseT-half,10M-baseT-full,100M-baseT-half,100M-baseT-full,1G-baseT-half,1G-baseT-full,1G-baseX,
2.5G-baseT,2.5G-baseX,5G-baseT,10G-baseT,10G-baseSR-LR,10G-baseCR
sfp-supported: 1G-baseX,10G-baseSR-LR,25G-baseSR-LR,100G-baseSR4-LR4
advertising: 1G-baseX,10G-baseSR-LR
link-partner-advertising:
sfp-module-present: yes
sfp-rx-loss: no
sfp-tx-fault: no
sfp-type: SFP/SFP+/SFP28/SFP56
sfp-connector-type: LC
sfp-link-length-om3: 70m
sfp-link-length-copper-active-om4: 10m
sfp-vendor-name: MikroTik
sfp-vendor-part-number: XS+85LC01D
sfp-vendor-revision: 1.0
sfp-vendor-serial: OL2403200701
sfp-manufacturing-date: 24-03-20
sfp-wavelength: 850nm
sfp-dwdm-channel-spacing: 2Ghz
sfp-temperature: 35C
sfp-supply-voltage: 3.276V
sfp-tx-bias-current: 7mA
sfp-tx-power: -0.446dBm
sfp-rx-power: -6.196dBm
eeprom-checksum: good
eeprom: 0000: 03 04 07 10 00 00 00 00 00 00 00 06 ff 00 00 00 ........ ........
0010: 00 00 0a 07 4d 69 6b 72 6f 54 69 6b 20 20 20 20 ....Mikr oTik
0020: 20 20 20 20 02 00 00 00 58 53 2b 38 35 4c 43 30 .... XS+85LC0
0030: 31 44 20 20 20 20 20 20 31 2e 30 20 03 52 00 9b 1D 1.0 .R..
0040: 0a 1a 67 00 4f 4c 32 34 30 33 32 30 30 37 30 31 ..g.OL24 03200701
0050: 20 20 20 20 32 34 30 33 32 30 20 20 68 f0 08 64 2403 20 h..d
0060: 00 00 08 9f 55 10 34 2b e4 0e 71 50 14 58 05 0e ....U.4+ ..qP.X..
0070: 19 6f ee 00 00 00 00 00 00 00 00 00 1a 1d 89 42 .o...... .......B
0080: 64 00 d8 00 5f 00 dd 00 8c a0 6d 60 88 b8 71 48 d..._... ..m`..qH
0090: d6 d8 01 f4 c3 50 03 e8 6b 96 07 cb 55 76 09 d0 .....P.. k...Uv..
00a0: 9b 83 01 27 4d f1 02 4d 00 00 00 00 00 00 00 00 ...'M..M ........
00b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ........ ........
00c0: 00 00 00 00 3f 80 00 00 00 00 00 00 01 00 00 00 ....?... ........
00d0: 01 00 00 00 01 00 00 00 01 00 00 00 00 00 00 18 ........ ........
00e0: 23 9a 7f f8 0e 42 23 40 09 61 00 00 00 00 00 00 #....B#@ .a......
00f0: 00 00 70 20 00 00 01 00 00 00 00 ff ff ff ff 00 ..p .... ........
status: initializing
advertising:
sfp-temperature: 33C
sfp-supply-voltage: 3.306V
sfp-tx-bias-current: 0mA
sfp-tx-power: -40dBm
sfp-rx-power: -6.219dBm
00e0: 21 92 81 27 00 00 00 01 09 54 00 00 00 00 84 00 !..'.... .T......
00f0: 05 00 70 20 05 00 00 00 00 00 00 ff ff ff ff 00 ..p .... ........
Router #1
model = CCR2116-12G-4S+
add name=bridge1
add name=dhcp_pool0 ranges=192.168.22.2-192.168.22.254
add address-pool=dhcp_pool0 interface=bridge1 name=dhcp1
/port
set 0 name=serial0
add address=192.168.22.1/24 interface=bridge1 network=192.168.22.0
add address=65.58.155.1 interface=sfp-sfpplus2 network=255.255.255.224
add address=192.168.22.0/24 dns-server=8.8.8.8 gateway=192.168.22.1
add disabled=no dst-address=0.0.0.0/0 gateway=65.58.155.2 routing-table=main suppress-hw-offload=no
/system note
set show-at-login=no
/system routerboard settings
set enter-setup-on=delete-key
Router #2
add name=bridge1
add name=LAN
add name=dhcp_pool0 ranges=192.168.88.2-192.168.88.254
/port
set 0 name=serial0
/ipv6 settings
set accept-router-advertisements=yes
add address=192.168.88.1/24 interface=bridge1 network=192.168.88.0
add address=65.58.155.2 interface=sfp-sfpplus2 network=255.255.255.224
add address=192.168.88.0/24 dns-server=8.8.8.8 gateway=192.168.88.1
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=65.58.155.1 routing-table=main scope=30 suppress-hw-offload=no target-scope=10
/system note
On router #1... If I ping the local interface it responds but when I try to ping the remote it says 'no route to host'
[admin@MikroTik] > ping 65.58.155.1
SEQ HOST SIZE TTL TIME STATUS
0 65.58.155.1 56 64 50us
1 65.58.155.1 56 64 42us
2 65.58.155.1 56 64 43us
3 65.58.155.1 56 64 34us
sent=4 received=4 packet-loss=0% min-rtt=34us avg-rtt=42us max-rtt=50us
[admin@MikroTik] > ping 65.58.155.2
0 no route to host
1 no route to host
2 no route to host
3 no route to host
sent=4 received=0 packet-loss=100%
[admin@MikroTik] > [admin@MikroTik] >
You said your using “new single mode cable”. Single mode fibre on a multi mode SFP module is not very compatible.
Ugh. For some stupid reason I thought those SFPs were SM not MM. Doh! You are correct putting the right cable in there solves the problem.
