Hello everyone,
Since a few days I’m struggling to get my WireGuard setup working.
I have a successful handshake on the client, but cannot access any internal nor any internet resources anymore as soon as the WireGuard connection is established.
I tried to log the dropping firewall connections to the log, but cannot see any meaningful data?
Maybe somebody here has an idea or can point me to the right direction?
I have also attached my full config with export hide-sensitive
Thanks a lot and have a great day!
# 2024-04-17 22:29:13 by RouterOS 7.12.1
# software id = K1NV-BNTF
# model = RB4011iGS+
# serial number = D4480DA24C5E
add admin-mac=08:55:31:3B:D9:F5 auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] comment=";;; ok PC"
set [ find default-name=ether2 ] comment=";;; DATADUMP"
set [ find default-name=ether3 ] comment=";;; access point"
set [ find default-name=sfp-sfpplus1 ] comment=";;; glas"
/interface wireguard
add listen-port=13231 mtu=1420 name=wireguard1
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
/ip ipsec mode-config
add name=vpn-dhcp
/ip ipsec profile
set [ find default=yes ] enc-algorithm=aes-256,aes-128
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=aes-192-cbc,aes-128-cbc
add name=default-dhcp ranges=192.168.88.50-192.168.88.240
add name=dhcp-vpnpool next-pool=default-dhcp ranges=\
192.168.88.241-192.168.88.250
add name=ovpn-pool ranges=192.168.77.2-192.168.77.254
add address-pool=default-dhcp interface=bridge lease-time=10m name=defconf
/port
set 0 name=serial0
set 1 name=serial1
/ppp profile
add bridge=bridge local-address=192.168.88.1 name=vpn-ppp-profile \
remote-address=dhcp-vpnpool
add local-address=192.168.77.1 name=ovpn remote-address=ovpn-pool
/routing bgp template
set default disabled=no output.network=bgp-networks
/routing ospf instance
add disabled=no name=default-v2
/routing ospf area
add disabled=yes instance=default-v2 name=backbone-v2
add bridge=bridge comment=defconf ingress-filtering=no interface=ether2
add bridge=bridge comment=defconf ingress-filtering=no interface=ether3
add bridge=bridge comment=defconf ingress-filtering=no interface=ether4
add bridge=bridge comment=defconf ingress-filtering=no interface=ether5
add bridge=bridge comment=defconf ingress-filtering=no interface=ether6
add bridge=bridge comment=defconf ingress-filtering=no interface=ether7
add bridge=bridge comment=defconf ingress-filtering=no interface=ether8
add bridge=bridge comment=defconf ingress-filtering=no interface=ether9
add bridge=bridge comment=defconf ingress-filtering=no interface=ether10
/ip settings
set max-neighbor-entries=8192
/ipv6 settings
/interface l2tp-server server
set allow-fast-path=yes authentication=mschap2 default-profile=\
vpn-ppp-profile enabled=yes use-ipsec=yes
add comment=defconf interface=sfp-sfpplus1 list=WAN
add interface=wireguard1 list=LAN
/interface ovpn-server server
set auth=sha1,md5 certificate=ovpn-server
/interface wireguard peers
add allowed-address=192.168.100.2/32 comment=ok-phone interface=wireguard1 \
public-key="fltFWFh4u9An5cclF/eeu7LzNv1uZtgSeJvMo69PLQE="
add allowed-address=192.168.100.3/32 comment=sour-laptop interface=wireguard1 \
public-key="cKipB78OurOKCH22JV/09EOxABFYNrR/NIFDFTMgyE4="
192.168.88.0
add address=192.168.100.1/24 interface=wireguard1 network=192.168.100.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
# DHCP client can not run on slave or passthrough interface!
add interface=sfp-sfpplus1
/ip dhcp-server lease
add address=192.168.88.17 mac-address=00:11:32:76:37:22
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.17 comment=nas name=data.asdf
add action=accept chain=input comment="allow wireguard" dst-port=13231 \
log-prefix=allow-wireguard protocol=udp
add action=accept chain=input comment="allow wireguard traffic" log-prefix=\
allow-wireguard-traffic protocol=udp src-address=192.168.100.0/24
add action=accept chain=input comment="wireguard general" in-interface=\
wireguard1
add action=accept chain=forward comment="wireguard fwd" in-interface=\
wireguard1
add action=accept chain=forward comment="router to wireguard" dst-address=\
192.168.100.0/24 log-prefix=router-to-wireguard src-address=\
192.168.88.0/24
add action=accept chain=forward comment="wireguard to router" dst-address=\
192.168.88.0/24 log-prefix=wireguard-to-router src-address=\
192.168.100.0/24
established,related,untracked
invalid log-prefix=drop-invalid
add action=accept chain=input dst-port=500,1701,4500 protocol=udp
in-interface-list=!LAN log-prefix=drop-not-from-lan
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
connection-state=new in-interface-list=WAN log-prefix=drop-not-STNATed
add action=masquerade chain=srcnat out-interface=bridge src-address=\
192.168.88.0/24
add dst-address=192.168.88.0/24 gateway=ovpn-client1
/ip service
set telnet disabled=yes
set www-ssl certificate=www-ssl disabled=no
/ppp secret
add name=ok profile=vpn-ppp-profile
add name=cat profile=vpn-ppp-profile
add name=okvpn profile=ovpn
add name=catvpn profile=ovpn
/routing bfd configuration
add disabled=no interfaces=all min-rx=200ms min-tx=200ms multiplier=5
/system clock
set time-zone-name=Europe/Zurich
/system note
set note="Welcome!!!" show-at-login=no
/system resource irq rps
set sfp-sfpplus1 disabled=no
/tool mac-server
/tool mac-server mac-winbox
myFile.conf.rsc (8.27 KB)
