I’m trying to verbose import RSC file exported from CCR1009 device into new the same model device CCR1009 but I have errors like:
1
set discover-interface-list=discover
input does not match any value of discover-interface-list
so I moved this section on .rsc file to the end, but then again next error:
2.
interface list member
add interface sfp-sfpplus1 list=Lan+ETH
input does not match any value of list
I understand why I have these errors, but I have over 1566 lines of config and now I have to guess what config section should be first what should be next, why Mikrotik do not export config in correct order, to resolve issues like these?
I have only done an import once - when I upgraded a RB750r2 with a RB750Gr3. I found the same thing. Had to break up the file into a bunch of small pieces to get it all to work. Like you, stuff was in the wrong order, and stuff in the default config conflicted with what I was trying to import. Ended up taking an hour or two.
