Cannot log with winbox
Hi Guys
I setup a MT with 3.10 and pptp server. I disabled ftp,telnet,ssh and by accident www in /IP SERVICES :open_mouth:
After I logged out of winbox and tried to log in again I get (port 80) Server error.
If I pptp vpn into the MT and try to winbox to the vpn ip I get Web Server Not Running.
I can connect via browser to MT and login with webbox - but can’t do much there.
Any help would be appreciated.
Using MAC WinBox should work. Press the “…” button in the WinBox start dialog.
It should discover the router (if connected to the same LAN). By clicking on the displayed MAC address you should be able to connect. Then re-activate what you need in “/ip service”…
Hi cmit
I will try that as last effort, I am trying to connect remotely -
I’ll phone the guy tomorrow and ask him to do that.
Thanks for your quick response.
