Cannot login from android device
Masters,
I installed Android Winbox Free 2.0 on my phone.
On Winbox (windows) i run this command: /ip service enable api
After i try to connect from phone, i see this on the log file:
login failure for user XXX from xx.xx.xx.xx via api
What should i check?
Any suggestion apperciated.
Thank you
Hi Holian,
It is recommended to use webfig instead of others on android.
Please use it; It is my suggestion.
How could i reach this web based config?
Tnx
sorry…i got it..our isp change the default port of webfig..
