cannot login with serial consol or lan
hi guys
I just bought this routerboard 532 with routeros installed already, I tried neighborviewer and it does not detect it so I tried serial cable connecting to my port and setting up the datarate and parity but still no login page on hyperterminal,
here i attached a photo from my cable showing its diagram, (it suppose to be null-modem cable)
thanks
btw: the blue and orange and Lan1 leds are all blinding like twice a second.
Have you reference a null modem cable pinout diagram.
Here is one. Null Modem Pinout
Also make sure that you turn the flow control off.
setting should 9600 8N1 if IIRC.
Dan
The RouterBOARD manual has a known-to-be-good full null-modem cable pinout. I have a cable made after that design on my desk, and it is working flawlessly (if it does not, try playing with flow-control option of your terminal program). Also, for the RB500, the default bitrate is 115200.
after all changing diagram it still has problem to login and I called the reseller and they told me if the orange light stay on, it means that there is a hardware problem and there is one chip on the board next to the memory which is very small (around 5mm) it will get extremely hot
