I own a CRS125 which I normally reseted using the reset button procedure described here http://wiki.mikrotik.com/wiki/Manual:Reset. After the reset, the CRS went into a reboot loop every 6 sec.
Plugging a serial console reveals the following:
CRS125-24G-1S-2HnD
CPU frequency: 600 MHz
Memory speed: 200 MHz
Memory size: 128 MiB
NAND size: 128 MiB
loading kernel from nand... kernel not found
RouterBOOT booter 3.22
CRS125-24G-1S-2HnD
NAND size: 128 MiB
CRS125-24G-1S-2HnD
NAND size: 128 MiB
and the loop continues forever..
What I get from the above is that it doesn’t find a local kernel, but it doesn’t look at the network in order to netinstall.
Just to clarify things, shouldn’t it display anything like ‘Press any key’ or counting down to zero till it continues with booting? It displays none of these, just the loop that I posted before.
G2Dolphin, Paul, I will try again tomorrow making sure to press any key during boot, although I’m quite sure that I have already tried without any effect.
I will also compare normal booting from another board.
Well, the good news is that I succeeded with netinstall
The 2 second count down was displayed only when the reset button was pressed. It seems that I missed it with hyperterminal and I hit it when I used putty instead.
The “RouterOS cleanup…” section appeared only during the full rese procedure (power jack off, press reset and insert power). Then the press any key message appeared!
CRS125-24G-1S-2HnD
NAND size: 128 MiB
RouterOS cleanup...
writing settings to flash... OK
RouterBOOT backup booter 3.22
CRS125-24G-1S-2HnD
NAND size: 128 MiB
Press any key within 2 seconds to enter setup
Ethernet link absent...
trying bootp protocol................................. failed
kernel loading failed
Then after opening netinstall program
trying bootp protocol..................... OK
Got IP address: x.x.x.x
resolved mac address xx:xx:xx:xx:xx:xx
*transfer started ....*...................... transfer ok, time=6.29s
setting up elf image... OK
jumping to kernel code
memSize=126828
flashSize=133955584
Welcome to MikroTik Router Software remote installation
Press Ctrl-Alt-Delete to abort
and the procedure continued and completed successfully.
