Cannot Paste
hi,am facing big problem in how to paste in the webfig terminal,i couldn’t find a way to do that
It would better to paste using a terminal client ssh or telnet by recommendation.
thank u sir for ur reply and advice
but hw to paste through the webfig terminal,is there a way
I just faced same problem! Solved by using System → Scripts ->Press Add New
Then you Just paste your commands follow by ; at the end of each line. in the Source text box on the WebFig Page.
Type in your script Name that you want press Apply and press Run Script to start run your commands.
Hope this will help!! ^^ :smiley: :smiley:
very useful tip, thank you !!!
Big Thanks, it worked.
