CPE was registering and I was able to Mac Ping but not by IP address in following config:
AP’s ether a.b.c.1
AP’s wlan a.b.c.2, AP-Bridge mode
CPE’s ether a.b.c.10
CPE’s wlan a.b.c.11, Station mode
As mentioned in this forum and on documentation, I’ve also tried creating a bridge interfaced to ether and assigned a.b.c.2. Same thing to Station, created bridge to both ether and wlan. But with this method I wasn’t even able to Mac Ping.
Please help. Is there any good instruction for Point-to-Multipoint?
I notice that when adding a IP to two wireless interfaces on opposite sides, you sometiems have to login with mac telnet, and ping the IP of the Client side, from the AP.
then all works.
prob. some kind of bug as i would think it is ARP related, but ive seen it last hours with no resolution, until doing the mac telnet and ping of the clients IP.
jo2jo, if you are able to reproduce the issue, that is acting not as it should be, you have to report it to support with attached files and description, as well you have to make sure that issue is reproducable on different locations.
As IP address assignment should not cause any problems.
