Cannot Ping Gateway from VLAN Bridge
The Gist, Cannot Ping the Gateway from the VLAN Bridge on Router #2,
Router #1 Has two DHCP servers one on master port ether#2 and the other DHCP server is on VLAN 447
Router #2 can ping the gateway 100.64.10.1 from ether#24 but cannot ping the gateway from Bridge1. Bridge1 can pass traffic to where a computer plugged into ether#5 can receive a IP address but the PC cannot ping, winbox will even show both RBs in the neighbors list but I cannot pass a ping.
Thanks,
Config Router #1
set [ find default-name=ether2 ] name=ether2-master
set [ find default-name=ether3 ] master-port=ether2-master
set [ find default-name=ether4 ] master-port=ether2-master
set [ find default-name=ether5 ] master-port=ether2-master
/ip neighbor discovery
set ether1 discover=no
/interface vlan
add interface=ether2-master name=vlan447 vlan-id=447
/ip hotspot profile
add name=pool1-447 ranges=100.64.10.2-100.64.10.254
add address-pool=default-dhcp disabled=no interface=ether2-master name=defconf
add address-pool=pool1-447 disabled=no interface=vlan447 name=serv447
add address=192.168.88.1/24 comment=defconf interface=ether2-master network=\
    192.168.88.0
add address=100.64.10.1 interface=vlan447 network=100.64.10.1
/ip dhcp-client
add default-route-distance=0 dhcp-options=hostname,clientid disabled=no \
    interface=ether1
add address=100.64.10.0/24 gateway=100.64.10.1
set allow-remote-requests=yes servers=192.168.88.1
/ip dns static
add address=192.168.88.1 name=router
add action=accept chain=input comment="defconf: accept established,related" \
add action=drop chain=input comment="defconf: drop all from WAN" in-interface=\
    ether1
add action=accept chain=forward comment="defconf: accept established,related" \
add action=drop chain=forward comment="defconf: drop invalid" connection-state=\
    invalid
    "defconf:  drop all from WAN not DSTNATed" connection-nat-state=!dstnat \
    connection-state=new in-interface=ether1
add action=masquerade chain=srcnat comment="defconf: masquerade" out-interface=\
    ether1
/system clock
set time-zone-name=America/Chicago
/system routerboard settings
set cpu-frequency=650MHz
/tool mac-server
/tool mac-server mac-winbox
Router #2
add name=bridge1
set [ find default-name=ether1 ] name=ether1-master
set [ find default-name=ether2 ] master-port=ether1-master
set [ find default-name=ether3 ] master-port=ether1-master
set [ find default-name=ether4 ] master-port=ether1-master
set [ find default-name=ether6 ] master-port=ether1-master
set [ find default-name=ether7 ] master-port=ether1-master
set [ find default-name=ether8 ] master-port=ether1-master
set [ find default-name=ether9 ] master-port=ether1-master
set [ find default-name=ether11 ] master-port=ether1-master
set [ find default-name=ether12 ] master-port=ether1-master
set [ find default-name=ether13 ] master-port=ether1-master
set [ find default-name=ether14 ] master-port=ether1-master
set [ find default-name=ether15 ] master-port=ether1-master
set [ find default-name=ether16 ] master-port=ether1-master
set [ find default-name=ether17 ] master-port=ether1-master
set [ find default-name=ether18 ] master-port=ether1-master
set [ find default-name=ether19 ] master-port=ether1-master
set [ find default-name=ether20 ] master-port=ether1-master
set [ find default-name=ether21 ] master-port=ether1-master
set [ find default-name=ether22 ] master-port=ether1-master
set [ find default-name=ether23 ] master-port=ether1-master
set [ find default-name=sfp1 ] master-port=ether1-master
/interface vlan
add interface=ether24 name=447-WAN vlan-id=447
add interface=ether1-master name=477-Local vlan-id=447
add interface=ether1-master loop-protect-disable-time=0s \
    loop-protect-send-interval=0s name=vlan59 vlan-id=59
add name=dhcp_pool1 ranges=192.168.12.2-192.168.12.254
add address-pool=dhcp_pool1 disabled=no interface=ether1-master name=server1
add bridge=bridge1 interface=447-WAN
add bridge=bridge1 interface=477-Local
add address=192.168.12.1/24 interface=ether1-master network=192.168.12.0
/ip dhcp-client
    interface=ether24
    interface=bridge1
add address=192.168.12.0/24 dns-server=192.168.12.1 gateway=192.168.12.1
add action=masquerade chain=srcnat out-interface=ether24
/lcd interface pages
set 1 interfaces=ether13,ether14,ether15,ether16,ether17,ether18,ether19
/system clock
I think you should have a ARP problem
Repeat the ping meawhile you are checking routers ARP table.
