I am trying to reach my router thru IPv6 DDNS but when I checked it does not update with the IPv6 so I did a ping. Turns out I got a request timed out when trying to reach cloud2.mikrotik.com on IPv6. Any solution to this? Does my ISP blocking the IP or something? Because I can ping ipv6.google.com with success.
There’s an easy way to find out whether it is a firewall issue (even if the firewall was so selective that it would restrict access to cloud2.mikrotik.com but not to forum.mikrotik.com): use /tool traceroute.
If it shows no response at all, your own firewall or routing is to be blamed (or your ISP’s); if it does show some hops responding, the issue is located further in the network (possibly a firewall somewhere else, but more likely a routing issue, or maybe a DNS update issue at Mikrotik side).
I have the following picture, for forum.mikrotik.com:
[me@myTik] > /tool traceroute 2a02:610:7501:3000::239# ADDRESS LOSS SENT LAST AVG BEST WORST STD-DEV STATUS
1 xxxx:xxxx:xxxx::xxxx 0% 2 13.1ms 12.2 11.3 13.1 0.9
2 yyyy:yyyy:yyyy::yyyy 0% 2 22ms 18.3 14.5 22 3.8
3 100% 2 timeout
4 100% 2 timeout
5 2001:2034:1:c3::1 0% 2 41.3ms 43.8 41.3 46.3 2.5
6 100% 2 timeout
7 2001:2000:3080:21c8::2 0% 2 52.6ms 54.6 52.6 56.6 2
8 100% 2 timeout
9 100% 2 timeout
10 100% 2 timeout
11 100% 2 timeout
12 2a02:610:7501:3000::239 0% 2 50.3ms 50.3 50.3 50.3 0
For cloud2.mikrotik.com:
[me@myTik] > /tool traceroute 2a02:610:7501:1000::201# ADDRESS LOSS SENT LAST AVG BEST WORST STD-DEV STATUS
1 xxxx:xxxx:xxxx::xxxx 0% 3 13.4ms 12.9 11.8 13.4 0.7
2 yyyy:yyyy:yyyy::yyyy 0% 3 16.2ms 17.6 16.1 19.1 1.5
3 zzzz:zzzz:zzz:zzz::zzz 0% 3 19.1ms 18.9 18.4 19.1 0.3
4 100% 3 timeout
5 100% 3 timeout
6 2001:2034:1:c3::1 0% 3 42.6ms 43.9 42.6 46.4 1.7
7 2001:2034:0:85::1 0% 3 44.1ms 44.1 41.3 46.9 2.3
8 2001:2000:3080:21c8::2 0% 3 48.4ms 48.9 48.4 49.9 0.7
9 100% 3 timeout
10 100% 3 timeout
11 100% 3 timeout
12 100% 3 timeout
13 100% 3 timeout
(and the same for the other address, 2a02:610:7501:4000::251).
I can ping and traceroute forum.mikrotik.com with no problem, only cloud2.mikrotik.com I could not ping. I need this for the MikroTik DDNS to sync with my router IPv6 address since it still associate with the old IPv6 address prefix.
First, please don’t quote complete posts, especially if you react to a directly preceding one. There is no need to do so, this is not an e-mail message, the complete history of the conversation is always shown in the same window here.
Second, what I wanted to say by my post is that it is easy to find out whether the issue with access to cloud2.mikrotik.com is real or caused by your own firewall as @DarkNate suggests. And the conclusion is that at least in certain regions, there is a real issue and that it is likely to be at Mikrotik end given that forum.mikrotik.com can be pinged no problem whereas cloud2.mikrotik.com cannot.
So if it causes you a problem, open a support ticket with Mikrotik, either by sending an e-mail to support@mikrotik.com or, better, by using the web interface. forum.mikrotik.com is a self-help forum of fellow users, not an official input channel of Mikrotik support. You can refer to this forum topic in the ticket.
