I encounter a weird issue that I can’t manage to resolve.
I have a IKEv2 tunnel which was working fine until yesterday.
I can still ping devices on the other side, but the other side can’t ping devices on the LAN side of the Mikrotik.
He’s still able to ping the router tho.
What is weird, is that if I make a packet capture, I only see packets going in and out on the WAN interface, but none on the LAN interface, but the source and destination IP are always the same (source, the other party, destination, the device on my LAN).
This is more obvious with a logged firewall rule (the other party IP address is dumb, but it’s what he’s using on it’s LAN) :
forward: in:FTTO-ether1 out:FTTO-ether1, src-mac xx:xx:xx:xx:xx:xx, proto ICMP (type 8, code 0), 192.63.63.48->192.168.6.1, len 60
Since my bridge interface has an IP adress 192.168.6.252/24, I believe that there should be more like this :
forward: in:FTTO-ether1 out:bridge, src-mac xx:xx:xx:xx:xx:xx, proto ICMP (type 8, code 0), 192.63.63.48->192.168.6.1, len 60
If someone have an idea about what happens, I would be very grateful
Here’s my config :
add admin-mac=2C:C8:1B:C5:FD:2F arp=proxy-arp auto-mac=no comment=defconf \
name=bridge
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip ipsec profile
add dh-group=ecp256 dpd-interval=disable-dpd enc-algorithm=aes-256 \
hash-algorithm=sha256 lifetime=1h name=mistral
/ip ipsec peer
add address=XX.XX.XX.XX/32 exchange-mode=ike2 local-address=YY.YY.YY.YY \
name=MISTRAL profile=mistral send-initial-contact=no
/ip ipsec proposal
add auth-algorithms=sha256 enc-algorithms=aes-256-cbc,aes-256-ctr,aes-256-gcm \
lifetime=15m name=mistral pfs-group=modp2048
add name=default-dhcp ranges=192.168.0.100-192.168.0.149
add name=vpn-pool ranges=192.168.0.180-192.168.0.189
add address-pool=default-dhcp disabled=no interface=bridge name=defconf
/ppp profile
add change-tcp-mss=yes name=PPPoE only-one=yes use-compression=no \
use-encryption=no use-mpls=no use-upnp=yes
add change-tcp-mss=yes interface-list=LAN local-address=192.168.0.254 name=\
vpn only-one=yes remote-address=vpn-pool use-encryption=yes
/interface pppoe-client
add add-default-route=yes allow=pap,chap comment=Ftto-sfr disabled=no \
interface=ether1 name=FTTO-ether1 profile=PPPoE user=\
xxxxxxx@yyyyyyhjjjj
/snmp community
set [ find default=yes ] name=Monitoring write-access=yes
/system logging action
set 1 disk-file-count=5
/interface l2tp-server server
set enabled=yes max-mru=1360 max-mtu=1360 use-ipsec=required
add comment="RTE 4G" interface=ether2 list=WAN
add interface=FTTO-ether1 list=WAN
add interface=gre-tunnel1 list=LAN
add interface=gre-tunnel2 list=LAN
/interface sstp-server server
set certificate=WebFig
192.168.88.0
add address=10.0.2.2/24 comment="RTE 4G" interface=ether2 network=10.0.2.0
add address=172.16.0.1/30 interface=gre-tunnel1 network=172.16.0.0
add address=172.16.0.5/30 interface=gre-tunnel2 network=172.16.0.4
add address=192.168.0.254/24 interface=bridge network=192.168.0.0
add address=192.168.0.253/24 interface=bridge network=192.168.0.0
add address=192.168.0.252/24 interface=bridge network=192.168.0.0
add address=192.168.6.252/24 interface=bridge network=192.168.6.0
add address=192.168.0.0/24 comment=defconf gateway=192.168.0.254
set allow-remote-requests=yes servers=8.8.8.8,1.1.1.1,8.8.4.4
/ip dns static
/ip firewall address-list
add address=85.14.167.193 list=Unyc
add address=85.14.167.234 list=Unyc
established,related,untracked
add action=accept chain=input comment=IPSEC dst-port=500,4500 in-interface=\
FTTO-ether1 protocol=udp
add action=accept chain=input comment=L2TP dst-port=1701 in-interface=\
add action=accept chain=input comment=GRE in-interface-list=WAN protocol=gre
invalid
"Accept Webfig https connections from WAN" dst-port=8443 \
in-interface-list=WAN protocol=tcp
add action=accept chain=input comment="Accept SNMP conections from Unyc" \
dst-port=161,162 in-interface-list=WAN protocol=udp src-address-list=Unyc
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
/ip firewall mangle
add action=mark-connection chain=prerouting connection-mark=no-mark \
in-interface-list=LAN new-connection-mark=lan_cnx passthrough=yes
in-interface=FTTO-ether1 new-connection-mark=wan1_cnx passthrough=yes
in-interface=ether2 new-connection-mark=wan2_cnx passthrough=yes
add action=mark-routing chain=prerouting connection-mark=wan1_cnx \
dst-address-type=!local new-routing-mark=WAN1 passthrough=yes
add action=mark-routing chain=output connection-mark=wan1_cnx \
add action=mark-routing chain=prerouting connection-mark=wan2_cnx \
dst-address-type=!local new-routing-mark=WAN2 passthrough=yes
add action=mark-routing chain=output connection-mark=wan2_cnx \
add action=accept chain=srcnat dst-address=192.63.63.0/24 src-address=\
192.168.6.0/24
add action=accept chain=srcnat dst-address=192.168.6.0/24 src-address=\
192.63.63.0/24
add action=dst-nat chain=dstnat comment=NASILS dst-port=32443 \
in-interface-list=WAN protocol=tcp to-addresses=192.168.0.50 to-ports=\
8080
add action=dst-nat chain=dstnat comment=ATA dst-port=8181 in-interface-list=\
WAN protocol=tcp to-addresses=192.168.0.106 to-ports=443
/ip firewall raw
add action=notrack chain=prerouting dst-address=192.63.63.0/24 src-address=\
192.168.6.0/24
add action=notrack chain=prerouting dst-address=192.168.6.0/24 src-address=\
192.63.63.0/24
/ip firewall service-port
set sip disabled=yes
/ip ipsec identity
add peer=MISTRAL
/ip ipsec policy
add dst-address=192.63.63.0/24 peer=MISTRAL proposal=mistral src-address=\
192.168.6.0/24 tunnel=yes
add check-gateway=ping distance=1 gateway=FTTO-ether1 routing-mark=WAN1
add distance=2 routing-mark=WAN1 type=blackhole
add check-gateway=ping distance=1 gateway=10.0.2.1 routing-mark=WAN2
add distance=2 routing-mark=WAN2 type=blackhole
add check-gateway=ping distance=2 gateway=10.0.2.1
add check-gateway=ping distance=1 dst-address=192.168.2.0/24 gateway=\
172.16.0.2
add check-gateway=ping distance=1 dst-address=192.168.4.0/24 gateway=\
172.16.0.6
/ip service
set www-ssl certificate=WebFig disabled=no port=8443
/ppp secret
add name=sacchi profile=vpn service=l2tp
/snmp
set enabled=yes
/system clock
set time-zone-name=Europe/Paris
/system identity
set name=ILS-Pegomas-MikroTik
/system leds
set 0 interface=wlan1 leds=led1,led2,led3,led4,led5 type=\
wireless-signal-strength
set 1 leds=poe-led type=poe-out
/system ntp client
set enabled=yes server-dns-names=fr.pool.ntp.org
/system package update
set channel=long-term
Joris
