cannot ping or access different class Ips from my pc
As i said in one previous post the job here is awesome and you must keep up because you help many people and personaly i appreciate that :slight_smile: !
:confused: In my problem know because i need your knowledge guys !.!
After upgrading my RB493AH to v.6.38.5 i have one problem.
Lets start from the beggining…I have 3 wan connections (one pppe and two wan-ethernet).My problem is that when i assign static IPs to my pc i cannot access WAN2 & WAN3.
WAN2 (192.168.1.152 Engenius 5610 as wireless client to 192.168.1.1 modem-router)
WAN3(192.168.200.200 SXT as wireless client too)
Also the problem remains when i get dhcp address from RB.I noticed that even with only static ip in my pc for example 192.168.1.50 i run angry ip scanner i cannot find any device in range of
192.168.1.1-192.168.1.254.
The IP of RB is 10.10.10.10/24 . When i ping from terminal RB can see every device on the network in the same or different Class of IP but my pc or other devices in the LAN or WIFI cannot.
Also i have to mention tha load balance with 3 WANs works perfectly and port forwarding (with “Sob’s” help, of course) works too.
Please help…
