Cannot ping out of LAN interface on OSPF
Hello everyone,
I am rather new to networking with OSPF. It appears that I have ran into a little issue that I thought I would ask the forum about.
I am routing multiple networks together and I have OSPF working and pinging on all my routers. As in, I can ping to everywhere from a router. But I cannot ping from a host on the subnet to another subnet. It appears that my LAN interface does not see the any other router than itself. How do I fix this? See the output from one of my routers below:
0 D interface=LAN cost=10 priority=1 authentication=none authenticati
authentication-key-id=1 network-type=broadcast instance-id=0
retransmit-interval=5s transmit-delay=1s hello-interval=10s
dead-interval=40s use-bfd=no ip-address=10.5.8.1
used-network-type=broadcast state=designated-router instance=defa
area=area1 neighbors=0 adjacent-neighbors=0 designated-router=10.
backup-designated-router=0.0.0.0
1 D interface=ether2 cost=10 priority=1 authentication=none
authentication-key=“” authentication-key-id=1 network-type=broadc
instance-id=0 retransmit-interval=5s transmit-delay=1s hello-inte
dead-interval=40s use-bfd=no ip-address=10.0.3.2
used-network-type=broadcast state=backup instance=default area=ar
neighbors=1 adjacent-neighbors=1 designated-router=10.0.3.1
backup-designated-router=10.0.3.2
2 D interface=ether1 cost=10 priority=1 authentication=none
dead-interval=40s use-bfd=no ip-address=10.0.5.2
area=area1 neighbors=1 adjacent-neighbors=1 designated-router=10.
Just gonna update with some more info.
/ip route> print
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme,
DST-ADDRESS PREF-SRC GATEWAY DISTANCE
0 ADo 10.0.1.0/29 10.0.5.1 110
1 ADo 10.0.2.0/29 10.0.3.1 110
2 ADC 10.0.3.0/29 10.0.3.2 ether2 0
3 ADo 10.0.4.0/29 10.0.5.1 110
4 ADC 10.0.5.0/29 10.0.5.2 ether1 0
5 ADo 10.0.6.0/29 10.0.5.1 110
10.0.3.1
6 ADo 10.0.7.0/29 10.0.5.1 110
7 ADC 10.5.8.0/24 10.5.8.1 LAN 0
8 ADo 10.5.9.0/24 10.0.3.1 110
9 ADo 10.5.10.0/24 10.0.5.1 110
10 ADo 10.5.23.0/24 10.0.5.1 110
11 ADo 10.5.55.0/24 10.0.5.1 110
12 ADo 10.5.60.0/24 10.0.3.1 110
13 ADC 10.10.8.1/32 10.10.8.1 Lo0 0
14 ADo 10.10.9.1/32 10.0.3.1 110
15 ADo 10.10.10.1/32 10.0.5.1 110
16 ADo 10.10.23.1/32 10.0.5.1 110
/routing ospf route> print
DST-ADDRESS STATE COST GATEWAY INTERFACE
0 0.0.0.0/0 imported-ext-1 1
1 10.0.1.0/29 intra-area 20 10.0.5.1 ether1
2 10.0.2.0/29 intra-area 20 10.0.3.1 ether2
3 10.0.3.0/29 intra-area 10 0.0.0.0 ether2
4 10.0.4.0/29 intra-area 30 10.0.5.1 ether1
5 10.0.5.0/29 intra-area 10 0.0.0.0 ether1
6 10.0.6.0/29 inter-area 30 10.0.3.1 ether2
10.0.5.1 ether1
7 10.0.7.0/29 inter-area 20 10.0.5.1 ether1
8 10.5.8.0/24 intra-area 10 0.0.0.0 LAN
9 10.5.9.0/24 intra-area 20 10.0.3.1 ether2
10 10.5.10.0/24 intra-area 30 10.0.5.1 ether1
11 10.5.23.0/24 intra-area 20 10.0.5.1 ether1
12 10.5.55.0/24 inter-area 30 10.0.5.1 ether1
13 10.5.60.0/24 intra-area 30 10.0.3.1 ether2
14 10.10.8.1/32 intra-area 10 0.0.0.0 Lo0
15 10.10.9.1/32 intra-area 20 10.0.3.1 ether2
16 10.10.10.1/32 intra-area 30 10.0.5.1 ether1
17 10.10.23.1/32 intra-area 20 10.0.5.1 ether1
Never mind. It was a layer 8 issue. The host I was trying to ping from was trying to send the icmp traffic out the wireless interface instead of the NIC.
