cannot ping out to internet from lan
i cannot ping out to the internet from my pc which is getting a dhcp address from ether2, but i am able to ping out to the internet from ether1 which is the internet port. I know it is a route but not sure what is going on I have a staic IP on the internet. Weird thing is that is when i ping it is doing a dns lookup so it is getting out but just not pinging
add address=64.122.42.210/30 broadcast=64.122.42.211 comment=“” disabled=no
interface=internet network=64.122.42.208
add address=192.168.12.1/24 broadcast=192.168.12.255 comment=“” disabled=no
interface=ether2 network=192.168.12.0
add address=192.168.13.1/24 broadcast=192.168.13.255 comment=“” disabled=no
interface=wlan1 network=192.168.13.0
add comment=“” disabled=no distance=1 dst-address=0.0.0.0/0 gateway=
64.122.42.209 scope=30 target-scope=10
add disabled=no distance=1 dst-address=192.168.0.0/24 gateway=10.0.0.15
/interface pptp-client
add add-default-route=no allow=pap,chap,mschap1,mschap2 comment=“”
connect-to=209.40.226.123 disabled=yes max-mru=1460 max-mtu=1460 mrru=
disabled name=xxxxxx password=“xxxxxxxx” profile=default-encryption
user=portland
set 0 arp=enabled auto-negotiation=yes comment=“” disabled=no full-duplex=yes
mac-address=00:0C:42:32:5C:86 mtu=1500 name=internet speed=100Mbps
set 1 arp=proxy-arp auto-negotiation=yes bandwidth=unlimited/unlimited
comment=“” disabled=no full-duplex=yes mac-address=00:0C:42:32:5C:87
master-port=none mtu=1500 name=ether2 speed=100Mbps
set 2 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited comment=
“” disabled=no full-duplex=yes mac-address=00:0C:42:32:5C:88 master-port=
none mtu=1500 name=ether3 speed=100Mbps
Please remove the username and password from your pptp-client config.
Do you have a masquerade rule in /ip firewall nat?
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s
tcp-close-wait-timeout=10s tcp-established-timeout=1d
tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s
tcp-syn-received-timeout=5s tcp-syn-sent-timeout=5s tcp-syncookie=no
tcp-time-wait-timeout=10s udp-stream-timeout=3m udp-timeout=10s
add action=masquerade chain=srcnat comment=“” disabled=no out-interface=
internet
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no
set pptp disabled=no
Are you able to ping from wlan1? Do the clients connected to ether2 receive a default route from the dhcp server?
For example:
[admin@rb450] > ip dhcp-server network print
 # ADDRESS            GATEWAY         DNS-SERVER      WINS-SERVER     DOMAIN
 0 192.168.88.0/24    192.168.88.1
[admin@rb450] >
0 192.168.12.0/24 192.168.12.1 192.168.12.1
1 192.168.13.0/24 192.168.13.1 192.168.13.1
Everything looks correct to me. :confused: Do you have any firewall filter rules that could be blocking the outgoing traffic?
see above for the firewall settings just right out of the box
I noticed on ether2 you have arp=proxy-arp. Do you have add-arp=yes on the dhcp server? Try enabling arp temporarily on that interface and see what happens.
it started working all of a sudden i didn’t change anything. So thanks for your help.
I was thinking like you had arp set to reply-only, so add-arp=yes does not need to be set on the dhcp server. Glad it started working… for whatever reason.
