Hi all,
Newly installed a RB450G with version 6.33.5.
This MT router (eth2) is connected to my Firewall (192.168.100.1) with IP: 192.168.100.2.
From my Firewall (192.168.100.1) and the MT (192.168.100.2), I can access both devices from both devices.
From the MT Router (eth4: 192.168.200.1) which is configured as a PPPoE concentrator, an Access Point (192.168.200.2) is connected.
My problem is that from the Firewall, I am not able to ping either the MT eth4 (192.168.200.1) or the Access Point (192.168.200.2).
If I connect a laptop to MT Router (eth4: 192.168.200.1) and dial PPPoE, it gets connected and access everything on the Firewall and Internet.
My only problem is that from outside the Firewall, I can’t access MT Router (eth4: 192.168.200.1) and anything behind it?
I think it is simply a basic problem but I will appreciate your help and suggestions on this.
Thanks,
Sanay
