Cannot ping to other subnet
i cannot ping from PC1 (192.168.1.11) on eth1(bridge PRIVATE, mikrotik 192.168.1.7) to 192.168.77.3 on eth4(bridge WIFI, mikrotik 192.168.77.1).
Neither can I ping to mikrotik address 192.168.77.1.
Where am I missing?
Thank you
add address=192.168.77.1/24 interface="Bridge HOTSPOT" network=192.168.77.0
add address=192.168.1.7/24 interface="Bridge PRIVATE" network=192.168.1.
add distance=1 gateway=192.168.1.2 routing-mark=12345
add distance=1 gateway=192.168.1.1
/ip firewall mangle
add action=mark-routing chain=prerouting new-routing-mark=12345 src-address=192.168.77.0/24
add action=passthrough chain=unused-hs-chain comment="place hotspot rules here" disabled=yes
add chain=input comment="default configuration" protocol=icmp
add chain=input comment="default configuration" connection-state=established
add chain=input comment="default configuration" connection-state=related
add action=passthrough chain=unused-hs-chain comment="place hotspot rules here" disabled=yes to-addresses=0.0.0.0
add action=masquerade chain=srcnat out-interface="Bridge PRIVATE" src-address=192.168.77.0/24 to-addresses=0.0.0.0
add address=192.168.1.0/24 dns-server=192.168.1.7 gateway=192.168.1.7
add address=192.168.3.0/24 dns-server=192.168.3.1 gateway=192.168.3.1
add address=192.168.77.0/24  dns-server=192.168.77.1 gateway=192.168.77.
How come the gateways are the same?
It’s because of policy routing. Anything in the 77 network is forced to use the routing table 12345, which doesn’t contain any of your locally-connected subnets. (not even 77)
Make a routing rule:
/ip route rule add dst-address=192.168.0.0/16 action=lookup-only-in-table table=main
