How did you get your config so messed up? Did that tutorial tell you to remove the entire firewall?
Well, at least the firewall is not the cause of the problen, but not having a firewall will be the cause of a lot of trouble for you!
When I tutorial instructs you to empty the firewall filter list (and some of them do), discard it for the maker being clueless.
This is a trial router. It’s not my main router. I did not put a firewall to be sure that nothing was blocking wireguard. Once the problem is solved I will do the firewall as it should be.
Did you even read what I wrote ?
Check your ISP modem. Is that port being forwarded ??
If not, you can wait until Easter and Christmas fall on the same day.
Best to start clean WITH DEFAULT FIREWALL and then add the wireguard config again.
Add a firewall input rule for that one wireguard port (move it before the drop rule for the input chain) and see if the counter starts increasing when you try to start the tunnel.
Then you can troubleshoot further.
Port 13231 was already fowarded on my isp router. But don’t know verry well how to port foward 13231 since it’s a double nat. Please can you give me a script to foward 13231 on Mikrotik ?
The input chain is traffic to and fro the router, the brains, or the router services so to speak, vpn handshake being one of them.
The forward chain is for traffic through the router WAN to LAN, LAN to LAN, LAN to WAN, VPN TO LAN, LAN TO VPN etc..
As was stated,
netinstall a clean version of software and dont monkey with any rules you are not sure of, add wireguard and we can go from there to get wireguard working.
Tank you. I already started with clean version without any rules
I hope this diagram will help:
After the capsman default rule in the input chain is where you put add chain=input action=accept dst-port=13231 protocol=udp comment=“wireguard handshake”
Add your wireguard interface… and peers ( generate public key for your client, and get public key generated by client etc.)
Ensure that in the /interface list members you add /interface list members
add interface=ether1 list=WAN
add interface=bridge list=LAN add interface=wireguard1 list=LAN
Add your wireguard IP address along with existing bridge address.
DONE you should be able to connect…
add chain=input action=accept dst-port=13231 protocol=udp comment=“wireguard handshake” Done
Add your wireguard interface… and peers ( generate public key for your client, and get public key generated by client etc.) Done
add interface=wireguard1 list=LAN Done
Add your wireguard IP address along with existing bridge address. what do you mean ???
If you are trying from a pc connected to the MikroTik…what IP do you use to connect to? Might be that the ISP modem/router does not support NAT loopback.
Can you:
Test with a smartphone? => Check the counter on your MikroTik “wireguard handshake” rule, if hit you know port forwarding and firewall rule on the MikroTik is working
Test wit your computer and use the 192.168.50.1 IP address (to see if your Wireguard is running)?
A. do you have an accessible public WANIP??
B. are you being and ISP Router??
C. test from a cellular connection or from friends house.
When you enable IP cloud on the MT, is it the same WANIP your router shows under dhCP client settings and the same when you browse whats my ip?
( we dont want to see actual public IPs of course, for security reasons )
