Cannot reset LHG LTE18
Hi all,
I have a new LHG LTE18. I have set it up using Quickset (changed the IP and enabled DHCP server on the new range) and immediately lost access to the router. Unfortunately the reset button was somehow stuck, and when pressed multiple times, it broke off. The router was serviced and repair shop soldered a new reset button, but unfortunately it still does not work :frowning:
The router boots up, I can ping its IP, but it is not shown in Winbox (Neighbors), nor can I connect to it using admin credentials. SSH and telnet is also not working. I have also tried Netinstall, but since the reset buton seems to be not working, I can’t put it into Etherboot mode.
I am really out of luck here or is there some way I would be able to reset the router ?
Many thanks for any tips.
Michael
