Cannot Reset the password of the unit RB800
I have RB800 which i cannot access now using WinBox it shows wrong user/password and i already done do a RESET but still the problem occur, is anybody can help me how to solve this problem?
http://wiki.mikrotik.com/wiki/Manual:RouterOS_FAQ#Logging_on_and_Passwords
How can I recover a lost password?
If you have forgotten the password, there is no recovery for it. You have to reinstall the router.
http://wiki.mikrotik.com/wiki/Manual:Netinstall
Assuming you are looking at the board and the PCI slots are the top, see the upper-right mounting hole? See that little split-circular thing just below it? That’s the hardware reset jumper.
  1. Take a decently large phillips screwdriver and rest it in the center of the split-circular thing.
  2. Power on the router, leaving the screw driver in place.
  3. Wait for the double-beep, then try to log in (once you hear the double-beep, you can remove the screwdriver jumper)
You won’t retain the configuration, but you can now log in using the default IP/username.
