hi to all,
for educational purposes, I installed the dude on my 433ah, running the latest beta version. Unfortunatelly, it seems to always create a store, and I cannot see the packages any more, in order to deinstall it. There is only about 4 megs free storage, and the files screen also does not show any files!
I tried with telnet and terminal, but the result is the same, empty packages and files.
Is there a way to remove the dude (which I think caused the problem) or at least deactivate the package somehow, in order to regain control of the files and packages?
many thanks,
darengr
I think you need to reinstall RouterOS with Netinstall:
http://wiki.mikrotik.com/wiki/Netinstall
Not sure why this happened, though …
oh no!
this is the one using the null-modem serial cable, correct? I will try it in a few days, when I will be physically near the board.
many thanks for replying ![]()
darengr
