The only way how the 5ghz band is not suppoted is when in the cards eeprom nothing is written about the A mode. And in this file you send us there is no info about 5ghz form the eeprom. We don’t know how Windows or Madwifi are checking the band support for the cards.
Regards,
Uldis
Hmm. I just checked. Iv booted linux on one pc and intesrted that minipci card. I loaded Atheros modules and executed “dmesg” command. I can see very clearly that 5ghz A and SuperA are working just fine. By the way Windows and Madwifi are looking also at eeprom.
Also card is tested on 433AH routerboard, It works!
thats wrong, madwifi and the windows-driver do definitely not look in the eeprom. you got a card with a wrong eeprom, as i wrote in the other thread also, refund it and buy something working.
