Cannot set RB1100 MTU above 1600 bytes
Not sure if this is a hardware, software or usererror.
I have tried on RouterOS 4.10, 5b3 and 5b4.
I have two RB1100 and I cannot set MTU >1600:
[admin@m2] > /interface print
 #     NAME                                         TYPE             MTU   L2MTU
 0  R  ether12                                      ether            1500  1600
 1  R  ether13                                      ether            1500  1600
 2     ether11                                      ether            1500  1600
 3     ether6                                       ether            1500  1598
 4     ether7                                       ether            1500  1598
 5     ether8                                       ether            1500  1598
 6     ether9                                       ether            1500  1598
 7     ether10                                      ether            1500  1598
 8  R  ether1                                       ether            1500  1598
 9     ether2                                       ether            1500  1598
10     ether3                                       ether            1500  1598
11     ether4                                       ether            1500  1598
12     ether5                                       ether            1500  1598
[admin@m2] > /interface set mtu=9192 num=1
could not set mtu
[admin@m2] > /interface ethernet set mtu=9192 num=1
could not set mtu
[admin@m2] > /interface ethernet set l2mtu=9192 num=1
failed to update l2mtu
[admin@m2] > /interface set mtu=1600 num=1
 1  R  ether13                                      ether            1600  1600
The L2MTU indicates the largest possible frame to be transmitted by the inteface, right?
http://wiki.mikrotik.com/wiki/Manual:Maximum_Transmission_Unit_on_RouterBoards says the RB1100 should support up to 9498.
[admin@RB1100test] /interface ethernet> set ether2 l2mtu=9192
[admin@RB1100test] /interface ethernet> set ether2 mtu=9192
mtu can not be larger than l2mtu
Ahh, the syntax is different. This was confusing me.
[admin@m2] > /interface ethernet set numbers=1 l2mtu=9192
[admin@m2] > /interface ethernet set ether2 l2mtu=9192
[admin@m2] >
Thank you for your fast response!
This is unintuitive though, because all other settings in RouterOS are done via the ‘numbers=#’ syntax.
I’m not sure why using ‘set numbers=’ didn’t work for you. I’m running 4.10 and the following syntax works.
set numbers=8 l2mtu=9192
set 8 l2mtu=9192
set ether1 l2mtu=9192
set l2mtu=9192 [find name="ether1"]
Notice there are multiple supported syntax for changing values in ROS, not just numbers=#.
Sorry, user error.
ether11-13 on RB1100 are limited to 9116 bytes. 9192 is larger than 9116.
Strange though, because ether1-10 which are behind the switchchip can do 9498.
max l2mtu on ether11-13 is 9116
look at the table:
http://wiki.mikrotik.com/wiki/Manual:Maximum_Transmission_Unit_on_RouterBoards#MAC.2FLayer-2.2FL2_MTU
