I’m not the most experienced (I’m learning), and I thought I had everything set in place for SSHing into a device on the LAN, but when I try to SSH in from the WAN I SSH into the router and not the device on the WAN.
My RB is behind a modem and is connected to the Internet via PPPoE.
Here are my NAT rules:
[admin@MikroTik] /ip firewall nat> print
0 ;;; default configuration
chain=srcnat action=masquerade out-interface=(unknown)
1 chain=srcnat action=masquerade out-interface=pppoe-out1
2 chain=dstnat action=dst-nat to-addresses=192.168.1.64 to-ports=22 protocol=tcp in-interface=Internet dst-port=22
192.168.1.64 is the device I’m trying to access from the WAN. I can access it fine via SSH on the LAN.
The device is also running Apache, and when I replaced ports 22 with 80 in the NAT rules to test that, I still get the router’s login page from the WAN.
I’m not sure what I’m doing wrong, but if someone could point me in the right direction, that’d be a great help.
Thanks! ![]()
