Cannot start scripts by names from netwatch
I have a created a script list. So far I have started the scripts as directly listing their names in tools/netwatch, like shown on picture
After the last few updates stopped working the option that started the netwatch scripts with their names.
So it’s more convenient for clarity when starting two or three scripts sequentially. How can I start the scripts with their names?
Thank You.
Make sure that script you want to execute does not have more permissions that allowed by netwatch.
if I directly insert the text of the script then there is no problem.
There is no message in the log file that it has no startup rights
From chanelog:
*) netwatch - limit to read, write, test and reboot policies for Netwatch script execution;
Make sure that scripts does not exceed these policies.
Excuse me, I could not understand exactly what to do. I have to check script options in script Policies:read, write, test and reboot? Is that right?
Thank You. Solved with script Policies:read, write, test and reboot
