cannot starting after installation....
Please help to solve mikrotik installation problem
i had installed all the system and after install mikrotik asked to reboot..
so when i reboot
Loading system with initrd
Uncompressing Linux…Ok,Booting the kernel.
but..im wait untill 30 minutes not responding, it supposed to be starting…
Please help me to solve this :frowning:
Make sure you are using correct baud-rate; 9600, 115200.
Connect Ethernet cable from PC to Router, run Winbox on the PC and check if the router is available on this list.
If not try to reinstall once again.
hi re install the MK or check your PC hardware if u use pc or check your MK ver.
Set up the BIOS whit LBA in your hard disks and reinstall RouterOS
I SUPPOSE THAT YOU ARE USING AN ORIGINAL VERSION OF MIKROTIK.
