cannot transmit, failed to join recently
I am new with mikrotik routerboard. But I try to use RB433 for my wireless STATION.
I put my RB433+CM9 about 20m above the ground. CM9 can see a CISCO-BR350 (remote AP)
with signal strength -80 and noise floor -102.
When CM9 try to connect to BR350, it always fail even I have put the right WEP.
If I see in CM9 status, there is no Tx/Rx Signal Strength activity.
Is it becase my radio broken or not? so it doesn’t transmit anything, just can hear a signal from remote AP.
I am confuse where the problem is ? Software setting / my radio CM9 / pigtail ufl quality
or something else ?
I have search on forum.mikrotik.com with keyword “failed to join recently”, “noise floor”, etc
but not one of the result meet my criteria.
Any suggest ?
Change preamble-mode=long on AP and then try
