Cannot uninstall dude
Hello everyone,
I got myself a bit into (dude) trouble. I played around with an older version of dude but lost interest and disabled it. Now I wanted to take a second look at dude. Unfortunately, I cannot enable dude, because of an database error. That is why I wanted to uninstall and re-install the dude package on my RB4011. THe RB4011 ist running RouterOS 7.10.2.
However, neither disabling nor uninstalling the package under /system/packages does the trick. After the required reboot, the dude package is still there and enabled as a package, but not running due to the database issue. So I am stuck.
Any suggestions how to fix the issue?
Thanks alot!
Export config (make sure it is complete)
Netinstall
Apply config again (without dude)
Thanks for the advice. I guess I will have to try that. Although I hoped, there would be an easier solution.
