Under the system/packages menu on RB450G. When I press ‘download’ or ‘download & upgrade’ I get following error:
ERROR: missing routerboard-6.22-mipsbe.npk
what can be the cause. And how to fix it?
Thank you,
Rahul..
Thank you,
Rahul..
Again and again the same questions. Can’t you search before you ask? Download the latest mipsbe all packages zip file, extract the packages you want, copy them into router and reboot.
Did you what I suggested? Has it helped?
It is fault of mikrotik what they write on their main download page http://www.mikrotik.com/download. They should clearly state there that it is not possible to use single click automatic update procedure from lower major (5.x) to 6.x.
Then we would not need to read and answer the same questions again and again.
At least they write in the release notification e-mail this sentence (but not all administrators are receiving it):
If you already run some RouterOS v6.x version, simply click “Check for updates” in QuickSet, Webfig or Winbox packages menu.
Others: > http://www.mikrotik.com/download
It is not enough selfexplanatory as it does not say what others should do …
On the other hand, you are obliged to read manual before doing any changes. Have you read this:
http://wiki.mikrotik.com/wiki/Upgrading_RouterOS#Automatic_upgrade ?
As on all forums, none is happy to repeatedly answer the same questions. Hope you understand.
Enjoy 6.x!
I have issue trying to update rb1200 from 6.0beta2 version to 6.23 verson,
I have downloaded the correct package from the page, I did unzip the file and copy to option File into Mikrotik rb1200 using winbox, when reboot the Rb1200 no updated.
help me plase
thanks
I resolved the problem in the following ways:
manufactures a console cable, buy two female terminals and UTP cable (8hilos)
putty application for terminals (terminal windows are frizaba)
via console (putty configured for com1) between the router and configure it to do the boot for network card
then I could PLS the NetInstall application
install the new version of Firmware
then set to do the nand boot again
everything is working smoothly
Thanks for the help
