Cannot upgrade RouterBOOT
I’ve a RB433AH that freezes once time a week. So I’ve updated RouterOS but when I try to upgrade RouterBOOT this message show up.:
  MMMM    MMMM       KKK                          TTTTTTTTTTT      KKK
  MMM MMMM MMM  III  KKK  KKK  RRRRRR     OOOOOO      TTT     III  KKK  KKK
  MMM  MM  MMM  III  KKKKK     RRR  RRR  OOO  OOO     TTT     III  KKKKK
  MMM      MMM  III  KKK KKK   RRRRRR    OOO  OOO     TTT     III  KKK KKK
  MMM      MMM  III  KKK  KKK  RRR  RRR   OOOOOO      TTT     III  KKK  KKK
  MikroTik RouterOS 6.43.4 (c) 1999-2018       http://www.mikrotik.com/
[?]             Gives the list of available commands
command [?]     Gives help on the command and list of arguments
[Tab]           Completes the command/word. If the input is ambiguous,
                a second [Tab] gives possible options
/               Move up to base level
..              Move up one level
/command        Use command at the base level
[prodatas@MikroTik] > system routerboard
mode-button  settings  usb  export  get  print  upgrade
[prodatas@MikroTik] > system routerboard upgrade
Do you really want to upgrade firmware? [y/n]
y
ERROR: can not change firmware to this version, please try newer one
[prodatas@MikroTik] > system routerboard print
       routerboard: yes
             model: 433AH
     serial-number: 185C01F5008E
     firmware-type: ar7100
  factory-firmware: 2.15
  current-firmware: 3.41
  upgrade-firmware: 6.43.4
