Hi. I am trying to connect my Mikrotik to Verizon Fios which is their fiber to your door, but the dhcp client keeps sending packets and the server does not respond. The dhcp will hook up to a Linux box I have, but not to FIOS. I am not sure what the difference in the packets are as I cannot get a decent dump of just the dhcp packets. I can get pretty good in the router, but no possibility to get a dump on the Linux box – the tool won’t capture till the interface is up and is configured. I did notice one thing – if I send a client ID from the Linux box, it also times out, but I thought the MT was not sending the clientid, not just a null one. Anyway for the MT not to send the client ID at all, this may help solve my problem.
Thanks in advance for any suggestions.
