cant acces loacal server
:open_mouth: hi there
i have network weth local file server
when i enabel hotspot server in cant acces the file serve or ping it from any user pc
is ther any way to solve this proplem :open_mouth:
That would be localnet access. The requests from the localnet to 192.168 1.100 donโ€™t (or shouldnโ€™t) go through the hotspot. Your ip/netmask on the gateway is 192.168.1.1/24, correct? Also check โ€œ/ip dhcp-server networkโ€ to see if the netmask is correct.
And I presume the client ips increment. They are not all 192.168.1.101, correct?
hi
thanks for reply
user ip is 192.168.1.102-192.168.1.103
i used mikrotkOS as pppoe server 4 yaers ago and evry thig ok all yoser can acces the net and the local file server
i tray to use it as hotspot server user can see login page and login to internet but after enabel the hotspot they cant acces the file server or ping it if i disabel the hotspot server the user can ping any pc in my network and access the file server
my seting is
/ip dhcp-server> pr
NAME INTERFACE RELAY ADDRESS-POOL LEASE-TIME ADD-ARP
0 dhcp1 ether1 hs-pool-1 1h
[admin@MikroTik] /ip dhcp-server network> pr
ADDRESS GATEWAY DNS-SERVER WINS-SERVER DOMAIN
0 ;;; hotspot network
192.168.1.0/24 192.168.1.1
/ip hotspot profile
set default dns-name=โ€œโ€ hotspot-address=0.0.0.0 html-directory=hotspot
http-cookie-lifetime=3d http-proxy=0.0.0.0:0 login-by=cookie,http-chap
name=default rate-limit=โ€œโ€ smtp-server=0.0.0.0 split-user-domain=no
use-radius=no
add dns-name=โ€œโ€ hotspot-address=192.168.1.1 html-directory=hotspot
name=hsprof1 rate-limit=โ€œโ€ smtp-server=0.0.0.0 split-user-domain=no
use-radius=no
/ip hotspot
add address-pool=hs-pool-1 addresses-per-mac=2 disabled=no idle-timeout=5m
interface=ether1 keepalive-timeout=none name=hotspot1 profile=hsprof1
/ip hotspot user profile
set default idle-timeout=none keepalive-timeout=2m name=default shared-users=
1 status-autorefresh=1m transparent-proxy=no
/ip hotspot service-port
set ftp disabled=no ports=21
/ip hotspot user
add comment=โ€œโ€ disabled=no name=hass password=dream profile=default
is there any thing i miss ???
hi
thanks for reply
i tray to use it as hotspot server user can see login page and login to internet but after enabel the hotspot they cant acces the file server or ping it if i disabel the hotspot server evry thing work fin and user can ping any users PC and can access the file server
my seting is
/ip dhcp-server> pr
/ip hotspot profile
use-radius=no
use-radius=no
/ip hotspot
/ip hotspot user
hi
any bode can hellp
i still cant ping any host from any host so i cant access the file server or ping it from any host when i enabel the hotsopt server
plz hellp me
What interface is this hotspot on? It looks like ether1. That is normally my wan interface. What interface is your wan connection?
This might not help:
/ip hotspot profile
set default dns-name=โ€œโ€ > hotspot-address=0.0.0.0 > html-directory=hotspot
use-radius=no
That should be โ€œhotspot-address=192.168.1.1โ€.
EDIT: I see that hotspot-address was changed in a subsequent edit. Best for me if you use
/ip hotspot profile print
