Can't access any IPs from my subnet
My IPS provides me this static IP 5.172.XXX.XXX/8, and now I can’t access any sites that have IP from the same subnet, like 5.xxx.xxx.xxx. What should I do?
My config:
may/20/2018 03:31:10 by RouterOS 6.42.2
software id = NC3F-8D97
model = RouterBOARD 952Ui-5ac2nD
serial number = 71AF089D41B1
add admin-mac=CC:2D:E0:24:EC:81 auto-mac=no comment=defconf name=bridge
set [ find default-name=ether2 ] name=ether2-master
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-Ce distance=indoors frequency=auto mode=ap-bridge ssid=FGSFDS wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-Ceee disabled=no distance=indoors frequency=auto mode=ap-bridge ssid=FGSFDS wireless-protocol=802.11
add comment=defconf name=WAN
add comment=defconf name=LAN
add exclude=dynamic name=discover
add name=mactel
add name=mac-winbox
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=dynamic-keys supplicant-identity=MikroTik wpa-pre-shared-key=789456123 wpa2-pre-shared-key=789456123
/ip hotspot profile
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
/snmp community
set [ find default=yes ] addresses=0.0.0.0/0
add bridge=bridge comment=defconf interface=ether2-master
add bridge=bridge comment=defconf interface=wlan2
add bridge=bridge interface=ether3
add bridge=bridge interface=ether4
add bridge=bridge interface=ether5
set discover-interface-list=discover
add interface=wlan1 list=discover
add interface=wlan2 list=discover
add interface=ether2-master list=discover
add interface=ether3 list=discover
add interface=ether4 list=discover
add interface=ether5 list=discover
add interface=bridge list=discover
add interface=bridge list=mactel
add interface=bridge list=mac-winbox
add address=192.168.88.1/24 comment=defconf interface=ether2-master network=192.168.88.0
add address=5.172.xxx.xxx/8 interface=ether1 network=5.0.0.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid interface=ether1
/ip dhcp-server lease
add address=192.168.88.120 client-id=1:bc:5f:f4:85:15:e9 mac-address=BC:5F:F4:85:15:E9 server=defconf
add address=192.168.88.100 client-id=1:d0:22:12:db:5d:8c mac-address=D0:22:12:DB:5D:8C server=defconf
add address=192.168.88.110 client-id=1:10:a5:d0:cd:2f:88 mac-address=10:A5:D0:CD:2F:88 server=defconf
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
/ip dns static
add address=192.168.88.1 name=router.lan
add action=accept chain=input comment=“defconf: accept established,related,untracked” connection-state=established,related,untracked
add action=drop chain=input comment=“defconf: drop invalid” connection-state=invalid
add action=accept chain=input comment=“defconf: accept ICMP” protocol=icmp
add action=drop chain=input comment=“defconf: drop all not coming from LAN” in-interface-list=!LAN
add action=accept chain=forward comment=“defconf: accept in ipsec policy” ipsec-policy=in,ipsec
add action=accept chain=forward comment=“defconf: accept out ipsec policy” ipsec-policy=out,ipsec
add action=fasttrack-connection chain=forward comment=“defconf: fasttrack” connection-state=established,related
add action=accept chain=forward comment=“defconf: accept established,related, untracked” connection-state=established,related,untracked
add action=drop chain=forward comment=“defconf: drop invalid” connection-state=invalid
add action=drop chain=forward comment=“defconf: drop all from WAN not DSTNATed” connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=masquerade chain=srcnat comment=“defconf: masquerade” ipsec-policy=out,none out-interface-list=WAN
add action=dst-nat chain=dstnat comment=ONVIF dst-port=2000 in-interface=ether1 protocol=tcp to-addresses=192.168.88.100 to-ports=2000
add distance=1 gateway=5.172.xxx.xxx
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=bridge type=internal
add interface=ether1 type=external
/system routerboard settings
set silent-boot=no
/tool mac-server
set allowed-interface-list=mactel
/tool mac-server mac-winbox
set allowed-interface-list=mac-winbox
There’s about 99.99999% chance that /8 mask is wrong, ask ISP for correct one.
Yeah. Changing it to /24 solved the problem. Thanks.
