Can't access CSS106 connected through SFP
Hi!
I have a CSS106 connected to a CRS112 through sfp port. The SFP is connected, but the equipments connected in CSS106 doesn’t get IP. The CRS112 is working normally, givin address ip correctly. The SFP port is in bridge. The CSS106 appears in Neighbors with default IP.
The CSS106 is configured with default settings. What can i do to make things work?
Thanks a lot!
Set a fixed IP address (same network as the CSS) on the computer and connect with Winbox on the default IP address of the CSS.
