Cant Access HAP AC2 after hard reset
Im having trouble trying to acces my HAP AC2 after I hard reseted it (it had some basic configuration and a password I dont remember), it shows this error:
it doesnt work evenin legacy mode
you are out of luck. No easy way to recover.
Yep, after a hard reset, you have lost your config. The default log on was admin with no password. But more recently, the password is individualised to the router and should be on the label.
I doubt that is the case with this AC2 still being on ROS6 ?
Anyhow, if hard reset is already done, take it one step further and netinstall.
its weird because it worked, but i dont remember even using it in the first place, and its not the firs time i use this model or even this device, i always logged in using admin and no psswd
