for IPv4 , ping is OK, but can’t access Web.
for IPv6, very very slow.
Does Mikrotik banned all IPs of China Mainland?
I think that the question is: Does China block Mikrotik’s site?
yes,i am too ,how to do?it is show connection timed out
Is it just license.mikrotik.com or does www.mikrotik.com also not work?
If you need to renew/buy a license, and it’s not working, you might want to email support@mikrotik.com
All of them,both www and license site。
They can ping the sites, but can’t access http and https, seems some TCP blocking.
I think so, but ping is OK, http and https can’t be accessed.
But this forum works?
But I’m not sure it’s on the Mikrotik side. Other than the Back-to-Home feature might have caused scrutiny.
Dont feed the trolls.
It is possible China changed its policy recently. AFAIK, Mikrotik uses the same subnet for BTH as everything else.
I use VPN to access any sites out of china, including here.
It is reported by some other user that MT can’t be accessed.
Maybe you can use https://www.itdog.cn/tcping/ to check it.
What are you saying?
It was kinda rude. You’ve posted before. And easy to imagine there be problems connecting from China.
I think it more that no one here can help, you should email Mikrotik with output of traceroutes in case it is something on their side.
license.mikrotik.com and (www.)mikrotik.com are using TLS 1.3 (forum.mikrotik.com does not), from Wikipedia:
SSL protocols
In March 2020, China suddenly started blocking websites using the TLS (Transport Layer Security 1.3) and ESNI (Encrypted Server Name Indicator) for SSL certificates, since ESNI makes it difficult if not impossible to identify the name of a website based on the server name displayed in its SSL certificate.
