Hi, it’s strange situation, I’ve different networks on a router, for each one I have some NATs on public IP, if I try to access the publicaddress:natport-on the network A from network A it doesn’ work, from network B and C yes. The same for network B, if I try to access the publicaddress:natport-on the network B from network B it doesn’ work, from network A and C yes. It looks router can’t nat to the same network, and re rute packet. How to overcome this? thank you
If you connect to your servers using the LANIP address it will work fine.
If you connect from an external user to the server it will work fine.
If you connect to the server FROM WITHIN the same subnet BUT using the WANIP address of the router it will fail.
This is called a hairpin nat situation and requires an additional config.
thank you for your kind answer, which configuration I need to add?
Becuse there are mobile terminals that connects on LTE, but when under wifi it’s better to use wifi.. and without change the address.
If we use a classic router, it works, so I was thinking it won’t be that complicated
You need hairpin NAT.
I take issue with that article.
Look at the first example!
ip firewall nat
add chain=dstnat dst-address=1.1.1.1 protocol=tcp dst-port=80
action=dst-nat to-address=192.168.1.2
add chain=srcnat out-interface=WAN action=masquerade
a. the dstnat rule implies Static FIXED WANIP
b. the source nat rule implies a dynamic WANIP.
Lets say it is case A. then the example should have shown…
add chain=srcnat action=srcnat out-interface=WAN to address=1.1.1.1
Furthermore later on the solution for hairpin is not so smooth. For the fixed WANIP it merely needs an an additional hairpin srcnat rule..
add chain=srcnat action=masquerade dst-address=192.168.1.0/24 src-address=192.168.1.0/24
