So I have an 951G-2HnD as main router, and now I wanted to extend the wifi range to put a 951Ui-2HnD to the network as an AP. I configured it via the quick set as PTP Bridge AP. Everything works perfectly fine, except that I cannot connect to the 951U anymore, only if I directly connecting to the port2, and calling it by Mac address. If I am coming from the other router, it doesn’t find it. I am clearly missing something, but wasn’t able to figure out what. Do I have to add a new bridge with the port1 MAC address? How? This first bridge got created automagically. Or the firewall eating the connection?
# jan/02/1970 00:14:00 by RouterOS 6.46.4
# software id = THQV-7K46
# model = 951Ui-2HnD
# serial number = 4AC702DF0908
add admin-mac=D4:CA:6D:BE:0F:E3 auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
disabled=no distance=indoors frequency=auto installation=indoor mode=\
ap-bridge ssid=Mmmmmrgrgrgl wireless-protocol=802.11
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk group-ciphers=\
tkip,aes-ccm mode=dynamic-keys supplicant-identity=MikroTik \
unicast-ciphers=tkip,aes-ccm
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp interface=ether2 name=defconf
add bridge=bridge interface=ether1
add interface=ether2 list=LAN
add interface=ether3 list=LAN
add interface=ether4 list=LAN
add interface=ether5 list=LAN
add interface=wlan1 list=LAN
add address=192.168.88.2/24 comment=defconf interface=ether2 network=\
192.168.88.0
/ip dhcp-client
add comment=defconf interface=bridge
add address=192.168.88.0/24 comment=defconf gateway=192.168.88.2 netmask=24
set allow-remote-requests=yes servers=192.168.88.1
/ip dns static
add address=192.168.88.2 comment=defconf name=router.lan
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
add action=drop chain=forward comment="defconf: drop invalid" connection-state=\
invalid
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" \
connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=masquerade chain=srcnat comment="defconf: masquerade" disabled=yes \
add distance=1 gateway=192.168.88.1
/system routerboard settings
set cpu-frequency=750MHz
/tool mac-server
/tool mac-server mac-winbox
Okay, I reseted the config, and didn’t use quick setup. I set the AP, everything works fine if I set DHCP-client. If I try to give static IP, the router itself cannot reach the update and the time server, as I didn’t find out how to set gateway and DNS. Any tips?
Gateway: /ip route add dst-address=0.0.0.0/0 gateway=
The dst-address is optional in this case, the value in my example is default. If you want to set specific route to some network, then use of this part is mandatory.
DNS: /ip dns set allow-remote-requests=no servers=
Setting allow-remote-requests toggles the ability of clients to use router as DNS resolver. In typical home network it is usually set to yes, but then appropriate firewall rule has to block DNS requests originating from internet (default firewall rules on SOHO devices do that). Failing to do so makes router open for some DNS attacks and abuses. In case when device is used simply as switch/AP it’s more than sensible to set this parameter to no as in my example.
Thank you, it works fine. It’s ok the do no remote requests, as the clients asking the router anyway, this settings was required only for the AP itself, he doesn’t need to share the knowledge.
You already had this rule /ip route add distance=1 gateway=192.168.88.1
in your configuration…
That makes me wonder how exactly you solved the problem by adding a rule that was already there ?
Also, this rule is not needed if we want to access our device locally from within our LAN…
@zacharias: read post #5 … OP posted his current config without default route and explained he needed it for ROS upgrades and access to external NTP servers, etc.
Indeed it was, but you advised OP to reset to no config in post #4 and OP followed your advice.
The problem with newbies is that they don’t see nor understand things until they manage to capture some knowledge. I remember times when I was in the same boat as well regarding ROS. Now I recognise lack of knowledge on my part
