Can't access to an open network
Hi there,
I’m using a RB Metal 2SHPn with a 15db sector in outdoor.
This is an hotspot system with RouterOS 6.15 with latest firmware.
Other hotspot can see my ssid, my hotspot can see other hotspots but no terminal can’t see my hotspot.
Here is my config
/interface wireless
set [ find default-name=wlan1 ] adaptive-noise-immunity=none allow-sharedkey=no antenna-gain=0 area="" arp=enabled band=2ghz-onlyn basic-rates-a/g=6Mbps basic-rates-b=\
    1Mbps bridge-mode=enabled channel-width=20mhz compression=no country=italy default-ap-tx-limit=0 default-authentication=yes default-client-tx-limit=0 \
    default-forwarding=no dfs-mode=radar-detect disable-running-check=no disabled=no disconnect-timeout=3s distance=dynamic frame-lifetime=0 frequency=auto \
    frequency-mode=manual-txpower frequency-offset=0 hide-ssid=no ht-ampdu-priorities=0 ht-amsdu-limit=8192 ht-amsdu-threshold=8192 ht-basic-mcs=\
    mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7 ht-guard-interval=any ht-rxchains=0 ht-supported-mcs=\
    mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,mcs-15,mcs-16,mcs-17,mcs-18,mcs-19,mcs-20,mcs-21,mcs-22,mcs-23 \
    ht-txchains=0 hw-fragmentation-threshold=disabled hw-protection-mode=none hw-protection-threshold=0 hw-retries=15 interworking-profile=disabled l2mtu=2290 \
    mac-address=D4:CA:6D:62:C9:C1 max-station-count=50 mode=ap-bridge mtu=1500 multicast-buffering=enabled multicast-helper=default name=wlan1 noise-floor-threshold=\
    default nv2-cell-radius=30 nv2-noise-floor-offset=default nv2-preshared-key="" nv2-qos=default nv2-queue-count=2 nv2-security=disabled on-fail-retry-time=100ms \
    periodic-calibration=default periodic-calibration-interval=60 preamble-mode=both proprietary-extensions=post-2.9.25 radio-name=hotspot rate-selection=advanced \
    rate-set=default scan-list=default security-profile=default ssid=Hotspot station-bridge-clone-mac=00:00:00:00:00:00 supported-rates-a/g=\
    6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps tdma-period-size=2 tx-power=17 tx-power-mode=all-rates-fixed \
    update-stats-interval=disabled wds-cost-range=50-150 wds-default-bridge=bridge2-hotspot wds-default-cost=100 wds-ignore-ssid=no wds-mode=dynamic wireless-protocol=\
    unspecified wmm-support=disabled
/interface wireless manual-tx-power-table
set wlan1 manual-tx-powers="1Mbps:17,2Mbps:17,5.5Mbps:17,11Mbps:17,6Mbps:17,9Mbps:17,12Mbps:17,18Mbps:17,24Mbps:17,36Mbps:17,48Mbps:17,54Mbps:17,HT20-0:17,HT20-1:17,HT20\
    -2:17,HT20-3:17,HT20-4:17,HT20-5:17,HT20-6:17,HT20-7:17,HT40-0:17,HT40-1:17,HT40-2:17,HT40-3:17,HT40-4:17,HT40-5:17,HT40-6:17,HT40-7:17"
What could be my problem?
It’s very wrong choice run hotspot on band=2ghz-onlyn only N mode.
la stampante è solo “N”?
radar a 2ghz?
hw-retries=15
quest è meglio metterlo a 7
ssid=Hotspot
per compatibilità con quei troiai di Apple device, set it to HOTSPOT
usi il wds?
bridge-mode=enabled
disattiva il bridge o rischi di creare loop…
wds-mode=dynamic
meglio se dynamic-mesh
wireless-protocol=unspecified
mettilo a 802.11
