Hello My friends..!
so i try alot to access the usermanager menu using my browser to set the rules for my hotspot in my RB951ui, but all attemps was with the same error. - as you see in the picture below-
so please anyone have any idea why this hapen ..?
in the attached file you can find my mikrotik RB951ui config.
MK.rsc (2.31 KB)
what version ROS installed ?
v7.6
† User-Manager (v4)
R.I.P.
2013-05-XX - 2022-10-XI
7.x = no user-manager, or at least as you know,
it worked, so they changed it.
Instead of keeping something that worked, they replaced it with something else that didn’t do the same things.
non ti stare a rompere le balle con la 7.x, l’user-manager non c’è più, ora c’è l’“usermanager” che non centra più un sasso…
che rottura di zazzo quando decidono di dismettere le cose che funzionano per quelle che chissà quando funzioneranno…
thanks for your replay Mr.rextended, so yes unfortunately i know that.
The new user manager was announced almost 3 years ago. http://forum.mikrotik.com/t/new-user-manager-in-routeros-v7/135338/1
Anyway, I can’t imagine what shitty services you’re giving to clients from that RB951Ui in 2022.
Another fine Techsystem problem..
so yeah we support clients around the world, if you need support just contact me.
