i don’t know if you have a french support so i try to explain my problem in English.
I have a Mikrotik with RouterOS v6.39.2.
I can connect with my VPN, i have an ip adresse on the target network and can ping everybody in the network.
BUT, i’m not able to acces web UI on my IP Phone Yealink.
Here find my configuration :
admin@MikroTik] > /ip pool print
0 dhcp 192.168.11.100-192.168.11.199
1 PPTP IP POOL 192.168.100.100-192.168.100.200
[admin@MikroTik] > /ppp profile print detail
0 * name=“default” local-address=PPTP IP POOL remote-address=PPTP IP POOL idle-timeout=12h use-mpls=default use-compression=default use-encryption=default only-one=default change-tcp-mss=yes use-upnp=default address-list=“” dns-server=192.168.11.1 on-up=“” on-down=“”
1 name=“TEST” local-address=dhcp remote-address=dhcp use-mpls=default use-compression=default use-encryption=default only-one=default change-tcp-mss=yes use-upnp=default address-list=“” dns-server=192.168.11.1 on-up=“” on-down=“”
2 * name=“default-encryption” use-mpls=default use-compression=default use-encryption=yes only-one=default change-tcp-mss=yes use-upnp=default rate-limit=“128000/256000” address-list=“” on-up=“” on-down=“”
[admin@MikroTik] > /ppp secret print detail
0 name=“xxx” service=any caller-id=“” password=“xxx” profile=default routes=“” limit-bytes-in=0 limit-bytes-out=0 last-logged-out=jul/25/2016 22:19:13
1 name=“xxx” service=any caller-id=“” password=“xxx” profile=default routes=“” limit-bytes-in=0 limit-bytes-out=0 last-logged-out=may/01/2018 13:38:26
2 name=“xxx” service=any caller-id=“” password=“xxx” profile=default routes=“” limit-bytes-in=0 limit-bytes-out=0 last-logged-out=apr/30/2018 11:36:54
[admin@MikroTik] > /interface pptp-server server print
enabled: yes
max-mtu: 1450
max-mru: 1450
mrru: 1600
authentication: mschap1,mschap2
keepalive-timeout: 30
default-profile: default
[admin@MikroTik] > /ip firewall filter print detail
chain=input action=accept protocol=icmp in-interface=!ether1-gateway log=no log-prefix=“”
chain=forward action=accept in-interface=all-ppp log=yes log-prefix=“VPN”
chain=input action=accept in-interface=all-ppp log=yes log-prefix=“VPN”
chain=forward action=accept protocol=gre in-interface=ether1-gateway log=yes log-prefix=“VPN”
chain=input action=accept protocol=udp in-interface=ether1-gateway dst-port=1723 log=yes log-prefix=“VPN”
chain=input action=accept protocol=tcp in-interface=ether1-gateway dst-port=1723 log=yes log-prefix=“VPN”
chain=input action=accept connection-state=established,related log=no log-prefix=“DEFAULT REALATED INPUT”
chain=forward action=accept connection-state=established,related log=no log-prefix=“DEFAULT RELATED OUTPUT”
chain=input action=drop in-interface=ether1-gateway log=yes log-prefix=“drop input”
chain=forward action=drop connection-state=invalid log=yes log-prefix=“drop forward”
chain=forward action=drop connection-state=new connection-nat-state=!dstnat in-interface=ether1-gateway log=no log-prefix=“”
[admin@MikroTik] > /interface ethernet print
0 R ether1-gateway 1500 00:22:B0:68:33:87 enabled none switch1
1 S ether2 1500 E4:8D:8C:15:E1:A2 enabled none switch1
2 S ether3 1500 E4:8D:8C:15:E1:A3 enabled none switch1
3 RS ether4 1500 E4:8D:8C:15:E1:A4 enabled none switch1
4 S ether5 1500 E4:8D:8C:15:E1:A5 enabled none switch1
5 RS ether6-master-local 1500 E4:8D:8C:15:E1:A6 enabled none switch2
6 S ether7-slave-local 1500 E4:8D:8C:15:E1:A7 enabled ether6-master-local switch2
7 S ether8-slave-local 1500 E4:8D:8C:15:E1:A8 enabled ether6-master-local switch2
8 S ether9-slave-local 1500 E4:8D:8C:15:E1:A9 enabled ether6-master-local switch2
9 S ether10-slave-local 1500 E4:8D:8C:15:E1:AA enabled ether6-master-local switch2
10 S sfp1 1500 E4:8D:8C:15:E1:A0 enabled none switch1
[admin@MikroTik] > /ip firewall nat print detail
chain=srcnat action=masquerade out-interface=ether1-gateway log=no log-prefix=“”
chain=dstnat action=dst-nat to-addresses=192.168.11.5 to-ports=3389 protocol=tcpm in-interface=ether1-gateway dst-port=3389 log=yes log-prefix=“RDP SERVEUR”
Could you please help me ?
