I am a bit rusty as they run for years without touching!
Can’t get a DHCP server added - No such address pool
Anyone have their morning coffee and can see something missing?
poolerror.txt.rsc (1.65 KB)
You need to go to IP>Pool and create one first. Then make a reference to that Pool you just created
The pool was created, shows in print, and is in the dropdown.
Are you out of disk space? I see extra packages installed in the first screenshot and your export references user-manager (with errors) and it doesn’t show the pool you created.
That was it. Out of space to save pools.
