IP->DHCP server->Networks
Try to edit any of them, and doesn’t save the DNS settings (it works ok from winbox). Don´t know if its only me or where to report it.
V 6.20
I have the same problem, but in addition I can’t add the gateway and NTP server.
This is with Firefox.
Winbox can add all the values.
I had a similar problem previously in quickset.
http://forum.mikrotik.com/t/crs226-in-bridge-mode-will-not-accept-dns-in-quickset/77529/1
Strangely I found that if I rebooted the router, it was in fact set. It seemed to be more of a cosmetic / interface bug.
Are you seeing the same thing?
I can’t reboot the router until sunday, will try.
